why would you be using a 6x multi?
I believe it will only run at 8x in the second slot and personally id only bother water cooling the northbrigde.
just now a strange thing happen
on a bios optimized system, i get a bsod, didnt get all the information, but see a gdrv.sys
i google it and it seems to be a driver of giga software?
i uninstalled all the giga program now, but the gdrv.sys under C:/Windows is still here, do i need to delete it myself?
i am sure my ram are ok so the bsod should be related to the software
did i get a bad q9650?
i can get stable easy @ 4.2, 4.25
but when i raise to 4.3, 4.35
even i put 1.48v on core, 1.4 on vfsb, 1.63 on pll, 1.38,1.4 on mch, 2.1 on ram
other voltage leave as stock or auto
i just keep getting error in prime95 : fatal error final results are XXXXXXX, expected XXXXXXX
i dont get bsod or whatever, just error in it
so does it mean my q96 cant go over 4.3?
i tried to set the multi to x6, and it seems ok in prime95 (478X6)
sorry too many question
but want to now why the cores under prime95 are getting different test numbers?
for example finishing a 20K test, core0 may take 15, core 1 take 11(seems always 11 no matter the fft length), core2&3 take 14
where core 0 , 2, 3, usually are variable
test with different CPU Reference values and use Prime95 v25.11
P95 does each sub test (FFT) for 15mins, and cores are not 100% "same speed", 10sec diff in 30-40min will result in one FFT starting "one minute earlier" then the rest...and sometimes it just took 15min 2sec for one core to finish one FFT, the weaker has to do one test more ..and, notice how the number of iteriations increase at end of tests ? 10-15% longer time to finish one test. Or the faster core did 10 tests in 14mins and 59secs, it has to do one more test.
For my cpu, testing 4.2GHz, with notches too low vcore, gave error on the two first cores/workers with too high cpu ref value (~66-67% of CPU Term)
I lowered it to 63%(AUTO) and the error was moved to the two last cores/workers...so, there was only one left in the middle, 65%...but instead of error I had BSOD...raised vcore two notches and i'm soon 90mins clear on P95 blend/4.2GHz/1.3625v bios, 1.328v load...1.30v CPU Ref, 1.28v MCH
has there been UD3P bioses with CPU Reference A and CPU Reference B ? I'd want to set/test the lanes individually, 63% for cores 0+1 and 67% for the other two. Why is there only one cpu ref ?
Triton: try raising you mch up. The higher you go up the more you will need for sure. With default vtt-1.20v, .785 cpu ref and .80 mch ref seems to be a good spot, they are linked to the vtt so will raise along with it.. If i set .785 cpu ref .800 mch ref when it fails it is always core 4. if i use .760 cpu ref and .800 mch ref it is core 2 that fails. just the way it is. best results have been at .785 and .80.
OK, I had 2hr 17min Blend BSOD (error prior, but P95 still cant log usefully; dont know which core!!!) on my last try(4.2GHz), 1.30v CPU Term and 1.28v MCH, will try 1.30v MCH, and possibly play with lower CPU Ref and vcore... thx for tip
I did few hours prep before 9x467: 8.5x467 memtest86+...showed good, set tests #5 and #8 coz those have shown errors in individual test LOOP, but showed "OK" regularly.... also tested lowering vdimm...ram is 1.9v (2.1v max) 800mhz 5-5-5-18. board droops, so i get 2.064v in load..horrific if ram requires 2.1v...but I Memtested 2.04v (2.016v idle/2.000v load), all clear. i'm sure lower vdimm gives better oc.
sure, testing 1.30v CPU Term and 1.30v MCH,
CPU ref=one notch above "0.76(63%)", think 0.823v(=my best 65%=0.785v with 1.20v fsb).
MCH Ref I had to raise one or two notches, its 0.863v now I think (stopped using ET6..even temps got unreliable...cpu freq, fsb ,crap prog really). It's over 65% atleast. 67% maybe.
I have 1,35vcore and raised to 9x464 (4176MHz)...if it lasts Blend during my hangover...tip worth raising flag for !
Thx OC Nub, running P95 blend on my rig, surfing on borrowed laptop:
I see a clear differance, after 1024K was finished, each of the 4 cores switched to 8K FFT test instantly, no 2-3 sec slower core now. I'm sure this helps stability.
65% CPU Term(higher than auto), 67% MCH Term(higher volts than cpu term)
I belive in this :D
EDIT
Now at 10K, cores 0 and 1 are little faster than 2 and 3...well, cant comment that yet, requires a sixpack or two !
I always default to 1.20vtt and set ref's to desired value, mainly because I have a horrible memory and get the values wrong. But will adjust up or down a notch in et6 for tweaking.
I am trying to use Jor3lBR's templates to get my q9650 on 4.4 stable
but i keep getting fatal error : final results was XXXXXXX, expected XXXXXXX under small fft in prime95 on 3cores
why?
thanks
yes i understood what u said
but i am really having trouble to 4.4ghz
running this setting can get me passes 20 times IBTCode:******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ + 0.0 ]
CPU Frequency 4.33GHz............................[ 482 x 9.0]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 482 ]
PCI Express Frequency (Mhz).....................[ 101 ]
C.I.A 2.........................................[ Disabled ]
******Advanced Clock Control******
CPU Clock Drive.................................[ 1000mv ]
PCI Express Clock Drive.........................[ 1000mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
(G) MCH Frequency Latch.........................[ 400 ]
System Memory Multipler.........................[ 2.00B ]
Memory Frequency 1066...........................[ 964 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD[3].........................................[ auto ]
tWTR[3].........................................[ auto ]
tWR[6]..........................................[ auto ]
tRFC[52]........................................[ 52 ]
tRTP[3].........................................[ auto ]
Command Rate (cmd)[0]...........................[ auto ]
******Channel A Timing Settings******
Static tRead Value [ 8 ] ................[ auto ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 8 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.15 ]...................[ 1.38750 ]
CPU Termination [ 1.20 ]...................[ 1.30 ]
CPU PLL [ 1.50 ]...................[ 1.50 ]
CPU Reference [ 0.760 ]...................[ 0.87x( my memory is bad, but there is only one 0.87x ]
MCH Core [ 1.100 ]...................[ 1.320 ]
MCH Reference [ 0.760 ]...................[ 0.823 ]
MCH/DRAM Refernce [ 0.900 ]...................[ Auto ]
ICH I/O [ 1.500 ]...................[ 1.5 ]
ICH Core [ 1.100 ]...................[ 1.1 ]
DRAM Voltage [ 1.800 ]...................[ 2.100 ]
DRAM Termination [ 0.900 ]...................[ Auto ]
Channel A Ref [ 0.900 ]...................[ Auto ]
Channel B Ref [ 0.900 ]...................[ Auto ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
running this setting cant get me pass IBT 20 timesCode:******Motherboard Intelligent Tweaker (M.I.T.)******
CPU Frequency 4.4GHz............................[ 489 x 9.0]
CPU Host Frequency (Mhz)........................[ 489 ]
Memory Frequency 1066...........................[ 978 ]
CPU Vcore [ 1.15 ]...................[ 1.4250 ]
CPU Termination [ 1.20 ]...................[ 1.40 ]
CPU PLL [ 1.50 ]...................[ 1.57 ]
CPU Reference [ 0.760 ]...................[ tried 0.886~0.971 (5 options) ]
MCH Reference [ 0.760 ]...................[ tried 0.886~0.96x( 3 options) ]
ICH I/O [ 1.500 ]...................[ 1.57 ]
ICH Core [ 1.100 ]...................[ 1.2 ]
DRAM Voltage [ 1.800 ]...................[ 2.100~2.14 ]
there is no bsod just the screen freeze, the best one is passes 6 times
any idea?
thanks!
I'd try and increase your mch core. I need 1.36 for 470 fsb
Derek: you are not using enough mch, you will need at least 1.360v but more likely 1.40v, also try 200d-pl9 and leave MCH frequency latch to auto, maybe raise trfc a little if you are using a 2x2gb kit. Your skew is off, or advanced clock control, try 800/800/0/50 or maybe 900/900/0/50. If it still keeps failing you may just need more vcore. Post your system specs, make a sig. This will help people to see what you are working with.
Found more stability when lowering MCH/Dram Reference, Dram Termination and both Dram Channels TWO notches from "50%", all 1.01v @ 2.08v MEM
With AUTO or set 50% of VDIMM I had in best case errors on Blend @ 3-4min. I'm still using too low vcore for my test OC, but got 3-4x longer in Blend. Dunno if it only coz the "high" volts to ram, maybe not OK for 1.8v dimms?
(haha, ofcourse the rig rebooted, but got way further this time)
edit
seems I only have to lower Channel A & B References, leaving MCH/Dram Ref and Dram Term at auto/50%
really thanks for reply and help
aww, i always make mistake when filling in the setting
i actually set vmch to 1.4 when i was trying 4.4, but no luck
for the advanced clock control, 1000/1000 give me significant improvement when i was trying 4.3 and 4.33
i will try going to ram setting like you said, when i was trying 4.4ghz, i get errors in small fft prime95 within 3test for 2~3cores, seems to be the cpu problem?
