Mikee - I'm using x2 Corsair Twinx CMX512-3200XLPRO sticks which have the same 2-2-2-5 SPD timings. They've always worked fine at stock speeds at 1T and their rated 2.7v.
But as Losphoron suggests, you probably need to relax the timming on your memory to do any overclock.
I couldn't get mine above 214Mhz without doing so. System would reboot when going into Windows.
I'm new at this and still messing with the timmings, but give 2.5-4-4-7 a shot just for grins.
I was able to at least start going to higher HTT with those.
I got these timmings after looking at an old review for this RAM where they did a bit of testing on OC'ing them.
Those timmings may give you a starting point for yours.
I'm using Sideeffects 1C3 BIOS if that helps.
