Sideeffect, or another kind soul....I spent an hour reading this one thread, and have not yet found a list of complete settings and best BIOS to use for a SAFE BIOS setup....maybe with a little OC'ing for games like HL2/BF2.
I have had my K8N Neo2 Plat for 18 months with original A64 3500+, with stock air cooler, and OCZ matched pair Gold Rev2 500 x2.
I'm using the MSI 1.B Bios that MSI has on their site, and don't know if there is a better one to use. There are so many of the BIOS settings in the Cell section that I don't understand, it would be great if there was a more complete list of how to set them up.
I also have a XConnect 500W PSU, Audigy 2 X-Fi Fatality, ATI X800 XT PE, and 2 ATA Seagate Barracuda 160 GB drives. Running XP Pro. I am pretty much using default settings except these changes:
Advanced Chipset
AGP Aperture 256M
Fast Writes-Disabled
Integrated Peripherals
AC97 Controller Disabled
MAC Lan Auto
Onboard 1394 Enabled
Onboard LAN Controller Enabled (I have both Cable and DSL, so use both if one goes out)
IDE Devices Config all enabled except I disabled the 4 SATA items
RAID Config Disabled
I/0 Device Config FDC & Parallel Disabled
PnP/PCI Config
Primary Graphics Adapter AGP
Resources Controlled by Auto (ESCD)
Cell Menu
Current CPU Clock 2211 MHz (grayed out)
Current DDR Clock 400 MHz (grayed out)
DRAM Config
Timing Mode Auto
(Timings grayed out)
Bottom of 32-bit[31:24] IO [D0]
1T/2T Mem Timing [2T]
S/W memory hole Remapping Disabled
High Performance Mode Optimzed
Aggessive Timing Disabled
Dynamic OC'ing Sergeant
Clock Spread Spectrum Disabled
HT Frequency 4x
Cool n Quiet Disable
Adjust CPU Ratio Startup
Adjust CPU FSB Frequency 200
Adjust AGP Frequency 66
Adjust CPU VID Startup
CPU Voltage By CPU VID
Memory Voltage Auto
AGP Voltage 1.50 V
I OC'd my older rig using a Koolance water cooling tower with Asus A7N8X with Athlon 2700, but just never had the time to follow all the recommendations for this air cooled Neo2 A-64 3500+, so was hoping to get a shortcut guideline from the experts in this thread.
I sure appreciate any help you can give me!
