Some guys got lucky, IHS came of when they were trying to peel the fusion block from the NB.
Ouch thats nasty...
Wow. Don't think RMA will work for him!
What are safe temps for this NB? I've heard that at 45+ a lot of people experiance stability issues, but it seems like this thig runs hotter then that.
Mine was a steady 45-50c before I sent it in for RMA.
so maybe my temp expectations for this chipset were off, huh. I don
t feel like finding Intel's whitepaper on the x38 to find the "official" temp recomendations so have to go by what I hear. Anybody know what Intels recomendations are for the x38?
BTW. It doesn't seem like it's worth it to pop the heatsink off and reset with a better TIM or even a better cooler.
Tergon, what exactly are the temp issues you are having? im also having some problems. im gonna paste in the problem from my other post here:
i installed a qx9650 today and having an issue with the temp. temps are normal on all cores except the 2nd one. in core temp (0.95.4) they are : 22,41,19,20. bios reports cpu temp as 41, and so does speed fan. the asus probe software also shows 41 for cpu temp. i have not seen the 41 change at all. even when i run prime, the 41 remains constant. the other cores fluctuate normally.
btw first i had the problem in 0901. then i updated to 0902 and still having the same issue.
My temps on all four cores stay the same all the time mate. In probe, Speed fan and core temp. Evan with 12 Hours Dual Orthos and 6 Hours OCCT. It must be incorrect reporting by the bios.
I love this board !!!!!
My memory modules can run at PERFORMANCE LEVEL=4. 2.2V in bios.
alrite wtf is wrong with this board actually...pls sort me out i was like gonna be mad....today i have brought a thermalright 120 ultra extreme with scythe fan...to replace my artic cooling freezer 7...before i replace i was getting 45c in idle at 2.4ghz un oced....after replacing the tr i get the same 45c idle...i was like wtf? i reseat the damn heatsink for 5 times..i still get the same temp...the temp i reading is from everest. speedfan and bios temp monitor...all the same temp...wtf is going here? i supose that damn heatsink should be better then artic cooling
450x8 ran 10hours OCCT (slider in the middle) over night without any errors, and yesterday I also tested slider at cpu and at ram for each 30minutes without an error and Memtest, too. I think that must be stable, and here it is, with 400strap :)
BIOS 903
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : Auto
CPU Ratio Control : Manual
-Ratio CMOS Setting : Auto
FSB Frequency : 450
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: 1200
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 5
RAS# to RAS# Delay : 15
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
Ai Clock Twister : Light
Transaction Booster : Enabled
-Boost Level 1
CPU Voltage : 1.33500 1.320VCPU-z
CPU PLL Voltage : Auto
North Bridge Voltage : 1.29 1.30V Everest
DRAM Voltage : 2.16 2.19-2.21V Everest
FSB Termination Voltage : 1.38 1.42V Everest
South Bridge Voltage : 1.050 1.06V Everest
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : Auto
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED : Enabled
damn y cant i flash back to old bios? i now at 0903...i flashed with a usb pendrive..and now i cant flash back..
i've removed the heatsink on 2 boards now, they come off pretty easy with a hairdryer to heat up the gunk. some gentle lateral twisting and you shouldn't be in danger of removing the NB :)
i put a mcw30 onto mine and get ~31c under load with 1.5v - it's well worth it if you have a water loop running anyway.
anybody try installing LINUX and was actually successful?!?!?!
I think I'll wait til I have a quad on this thing and verify that my nb temps are holding me back. Right now my chip has a reasonable limit to it and pushing this board hasn't been a problem. I have an OCZ ram cooler so the nb gets plenty of air anyways. We'll see, but id on't plan on taking another nb heatsink off unless i have to. Bedes, I kinda like all that copper. It looks good in my case :D
so if everything is reporting temps incorrectly how are you supposed to tell what the hell the temp is? is this issue fixed in 0903? if not, is there an older bios version that does not have this issue? also, in my case since its only my 2nd core thats constant, can i assume its +-5 degrees of the other cores? im just afraid to start overclocking without getting a temp reading.
