Originally Posted by Sleepy Samurai
Hello All,
It has been a while. The advise I received in the past was very good and I would like some more.
I am starting to upgrade my system the specs are bellow. I would like to know if any other these Ram have been used before on the Neo2 Plat. and with what result?
Also is it worth upgrading or waiting? (cost per gain)?
Ram:
Mushkin XP PC4000 2GB 2X1GB DDR500 CL 3-4-3-8 184PIN DIMM Dual Channel Memory Kit
OCZ EL Gold GX XTC PC4000 2GB 2X1GB DDR500 CL3-4-3-8 184PIN Dual Channel Memory Kit
OCZ EL Platinum PC3200 2GB 2X1GB DDR400 CL2-3-2-5 184PIN Pin Dual Channel Memory Kit /W Ramsink
OCZ Gold EL PC4000 2GB 2X1GB DDR500 CL3-4-4-8 184PIN DIMM Dual Channel Memory Kit W/ Ramsink
System:
AMD 64 3200+ Veince w XP-90
MSI K8N Neo2 Plat. | 2x512mb Hynix BT 3500
200gb Seagate | ATI AIW x800 xt | SB Audigy Gamer
Many Thanks,
Sleepy
