Well that's why I stated that many users in here are not so extreme... as soon as you OC you are running out of spec and things aren't guaranteed... mobo/CPU/ram wise...
I only had one badly degraded Qx9650... prolly due too much CPU VTT on the 780i... never had it afterwards... if you read my post correctly many users push things on the stock cooler ( and there are many many or eg on a Freezer Pro)... temps readouts are so irregular on 45nm, some CPU's are smoking hot, some seem to be cold as ice... the general user will not be able to make anything out of it...
For some it's better to stick at 1.4volts, the benchers and co will not mind to push 1.6 on air or water and even more on extreme coolings... the crowd can take it anyway they want...I rather warn them of the consequences then to be :banana::banana::banana::banana::banana:ed upon later that they lost their overclock and have to settle for less...
