Originally Posted by
Hurtn4ASquirtn
Hi everyone my first post and im stoked to be part of the forums. I'm hoping someone can give me help to overclock my E8500 to 4.0 with this board. Any help is much appreciated here are my specs.
Mobo - Asus Maximus II Formula
Cpu - E8500 ( Zalman 9700 Cooler )
Ram - 2x2gig 8500 OCZ Reaper
Video - Vapour X 4890
PSU - 1200w Coolermaster
I have tried a few different things, On the settings below I lasted 1 hour and 6 mins before fatal error in prime 95. FATAL ERROR: Rounding was 0.5, expected less than 0.4 ( Is this a ram related error ? ) I have a bit of idea what im doing with the voltages but that's about it. ( Below is someone template I copied ) Please help where am I going wrong.
Ai Overclock Tuner [Manual]
OC From CPU Level Up [Auto]
Ratio CMOS Setting [9]
FSB Frequency [450]
CPU Clock Skew [Delay 100ps]
NB Clock Skew [Normal]
FSB Strap to North Bridge [Auto]
DRAM Frequency [DDR2-900MHz]
DRAM CLK Skew on Channel A1 [Auto]
DRAM CLK Skew on Channel A2 [Auto]
DRAM CLK Skew on Channel B1 [Auto]
DRAM CLK Skew on Channel B2 [Auto]
DRAM Timing Control [Manual]
CAS# Latency [5]
DRAM RAS# to CAS# Delay [5]
DRAM RAS# Precharge [5]
DRAM RAS# Activate to Precharge [15]
The rest of memory setting is at auto
DRAM Static Read Control [Disabled]
DRAM Read Training [Disabled]
MEM. OC Charger [Disabled]
Ai Clock Twister [Auto]
Ai Transaction Booster [Auto]
PCIE Frequency [100]
CPU Voltage [1.3625]
CPU PLL Voltage [~1.50]
FSB Termination Voltage [~1,30]
DRAM Voltage [~2,20]
North Bridge Voltage [~1,40]
South Bridge 1.5 Voltage [~1,50,one step above auto]
South Bridge 1.1 Voltage [~1,10, one step above auto]
CPU GTL Reference (0) [Auto]
CPU GTL Reference (1) [-40]
CPU GTL Reference (2) [Auto]
CPU GTL Reference (3) [Auto]
NB GTL Reference [-40]
DDR2 ChA Reference Voltage [Auto]
DDR2 ChB Reference Voltage [Auto]
North Bridge DDR Reference [Auto]
CPU Configuration:
C1E Support [Disabled]
Max CPUID Value Limit [Disabled]
Intel Virtualization Tech [Disabled]
CPU TM Function [Disabled]
Execute Disable Bit [Disabled]
Load-Line Calibration [Enabled, if disabled you may have to raise CPU voltage with 0,04v]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
