I thought my 9550 was good but damn these chips are awesome! Loaded vcore is 1.200, bios setting 1.20625 for 4ghz. :) Now its time to see what it can really do.
http://i131.photobucket.com/albums/p...mapImage2a.jpg
I was already running a Q6700, so I had the board dialed in even before I got the Q9650. I always test at different FSB speed intervals I feel are important (just drop the multi to 6x and test the FSB to its limits).
But yeah, there is a difference between a dual core and a quad, mainly voltages. The NB voltage (MCH for Gigabyte) is higher for a quad then a dual core. For example, on my previous ASUS P5E, I could run a 515 FSB with 1.43v NB. But with a quad, I could only run a 423 FSB with 1.45v NB.
With the UD3P, I've seen 500+ FSB with quads, but it takes 1.5v MCH. The default is 1.10v for 400 FSB, so you can see just how much that is. Yet the board can push 671 FSB with a dual core.
EOD thanks. HOSS331,great job,very low volts for 4ghz
Nice clockin' Hoss331, I can't wait to test mine out.
oh ya your going to like it :yepp:
thanks
whoopi! its here.batch #L826A965.looks like i got your twin here EOD.
I've just started testing mine. 1.1875 VID. started with 3.6 (only needs 1.20 vcore for stability with orthos). It may even go lower, I'm testing it in stages.
Well I had to make some changes to get it prime stable past 6 hours. To be stable at 4.25GHz I had to up the vcore to 1.368 which show an actual reading of 1.353. With this the idle temps were 38C and the prime load temps were 63C.
So far so good, 4.1 with 1.2312 bios. Im going to try for some 4.4 clocks next week, just breaking it in for now. :)
http://i131.photobucket.com/albums/p...mapImage2c.jpg
man, now these are so cheap I really want a new one. when seeing people like the guy above hit 4.1 ghz with less than my VID alone.. that sucks. lol I needed 1.25 to load at 3.0 Ghz.. sadness.
Still a great chip, but I want another.
So would my chip possibly reach higher overclocks with the same volts I'm using with other motherboards, some need lower volts than others to reach the same clocks right? or no, is that all how the CPU needs it.
Yea, these chips are finally cheap enough to warrant an upgrade from an Q6600. I wonder how many people are hitting over 4.0 with a Maximus?
You have a great chip Robilar! I started with my goal of 4.2Ghz and got that stable. Then today I decided to see what 4.0GHz would take. It took just +0.006v over vid:
http://i83.photobucket.com/albums/j2...GHz1256v_2.jpg
I have a Q6600 running at 3200 on a Abit P35. Would it be possible to get to to 4K with the Q9650 with a mild voltage bump with the P35 board? I know this looks like it would be possible with the P45 but if upgrade boards probably going to wait for a P55 and a i7 chip.
Looks like some great results so far....
yes, im running @4.0 right now on a MSI p35 NEO2 FR. This is a rev.1 board with bad VoltageReg (mucho vdroop). I think this is a 4 phase board.
P35 is still a respectable o/c board. Sure its no P45; but still...
I am really loving this chip
Btw.. on this motherboard with the crappy vReg. I had to run 1.6vCPU (bios) just to get my 6600 (1.325 vid) to run @3.6Ghz
With my 9650 it takes 1.28Vcpu to run @4.0 Ghz
my settings for the Nb were the same with the 6600 vs 9650 on this board. Only difference is the Vcore
Vtt 1.3 nb 1.45 sbio 1.8 sbcore 1.05
maybe i can lower them, but I haven't tried yet
9650 installed. quick run at stock to check and see if cpu is ok and to see how warm it runs.vid is 1.25.http://i43.tinypic.com/2wch9x0.jpg heres the first OC. still priming so far so good.pretty happy with temps so far.i will keep you guy posted. http://i41.tinypic.com/15nku13.jpg
Well 3825 MHz seems to be my cieling with this Zalman 9700 cooler :(
I have repeatedly with dozens of tweaks attempted 4GHz and just cant get windows to fully boot, I've come close getting past the password screen but it freezes shortly after loging in..
I have a vid of 1.16
Currently have stable occt 1 hr @ 1.175 425x9 = 3825MHz
I had to put a fan on my NB as it was pushing 50'c + now idling @43'c
I mainly played with the voltage and FSB i tried increasing my NB v but no effect there?
One thing that is bothering me is the load time to boot, my previous 6600 on gigabyte gax38DQ6 seemed much faster I count the times the bar rolls across the screen before the password prompt and it used to be 4-5 rolls across now It takes 10?? My benches are rocking @ just under 23,000 on 3dm'06 up from 18000 w/ the 6600 @ 3.4ghz I just cant seem to hit that 4ghz marker :( Any suggestions would be very welcome, heres my voltages
Asus Formula Maximus
Vcore 1.16v
cpu pll 1.632
NB v 1.632
Dram 2.32
FSB term 1.344
SB v 1.072
ddr2 controller ref v 1.152
SB 1.5v Voltage 1.552
Any help greatly appreciated
:shakes:
Vcore 1.16v to low set 1.25-1275v more maybe needed for 4ghz
cpu pll 1.632 set to 1.50- 1.54 in bios
NB v 1.632 to high try below 1.50
Dram 2.32 to high try lower <2.20
FSB term 1.344 ok for 4ghz
What to do about the abnormally high core temp? One core is 10c higher than the rest. Just ignore it?
Rest of the cores look great. I really dont think that one core is really 10c higher.
Thanks for these #'s but.... Still no go wouldn't even post 9 out of 10 times
:down:
Changed vcore incrementally from 1.25 up to 1.35
pll from 1.47 upto 1.54
NB from 1.48- 1.54v
Dram -2.18v
Any other ideas?
1.175v boots right up to 3.8 ghz ?
I know with a vid this Low stock it has to be able to hit 4 ghz.. I havent tried voltages over 1.4v so that might be the ticket just don't wanna fry the chip :) It might go though ?
:shakes:
Edit**
1 other item noticed, I was reading somewhere that it might be vista and that reinstalling a fresh copy might solve the problem?? Any possibility of this being true?
what is your vFSB/vtt at viccan?
well to actually run vista its @ 1.39v
ive tried uppin it to as high as 1.46v
Funny thing is even when i up my vcore to 1.206 which gets me to 3870mhz
My vcore in cpu-z as well as 3 other prgs. report it as 1.17 still?? should I kill the loadline cal and see if that helps??? I am completely stumped
Funnier is vista doesnt show the oc in the sys properties my q6600 always showed the stock then oc'd value??
vic:shrug:
so far so good. its a little scary as to the volts required to get 500fsb.but im on my way.http://i43.tinypic.com/2n7hb3q.jpg
thanks grn,heres my latest.im almost at my goal of 8x500@4.0ghz.but i wanted to run my ram at 5:6,for ddr 1200 pl8 but so far only able to run 1:1.so im 1/2 the way there.not liking the high volts though,any suggestions? could really use some help here.thanks.also i am very impressed with this proccessor.i had no idea there would be so much improvement in all aspects of its duties(yes i said doodies).i mean installing vista was fast,and everything loads so fast its ridiculous.it almost scared me when i clicked the opera browser button how fast it was up on the screen in front of me,its likeBAM there it is.http://i42.tinypic.com/2079sm8.jpg
just flashed to Rampage formula seems prettier but no beter luck?? This setting has to be there I got it to boot into safe mode @ 3.93 but thats the end of my success thus far couldn't do that on the old bios so this must have helped in some way??? HELP 1.12 vid its gotta go!!!
:shrug:
i dont believe it I set everything to normal except vcore (1.27v) and it booted seemed slow to boot and got an ugly smear accross screen at password prom,t but its up for once thankyou RAMPAGE!!
Temps seem high 39 39 38 38 idle ?? gonna play a bit see what come of it any pointers still greatly appreciated
Asus probe reports
vcore 1.27
sb 1.09
sb2 1.55
fsbt 1.39
dram 2.13
nb 1.63
nice one mcoffey! well ive finally got it stable at 500x8 half of my goal met,now to get the ram running 5:6 ddr 1200.http://i43.tinypic.com/2a856s3.jpg
whats your vid on this 9650? real temp tells me min= 1.0375 max= 1.1625
Ive currently got it at 1.28 and temps are somewhat high 39 39 40 41
had to over clock my NB to 1.73 just to get stable thus far i really need to get it down anyways any settings you might have would be appreciated i cant get over 4 ghz yet but i know its there just patience ....
Currently priming my new q9650 @ 3.9ghz at only 1.280v on air. :banana:(I'm using a maximus 2 formula)
This is definitely the best cpu I've ever owned.
viccan,my vid is 1.25 so it runs cooler than the lower vid chips, but i need more vcore.my temps are low also because i use an airconditioner.what are your ambient temps?cause if thier in the 65c-70c area, your cpu temps would be about right i think.im not familiar with your board so i cant really give you too much advice on settings.all my settings(main ones) are in the ss i posted. sorry i couldnt help much
My room temp is about 60' F heres a snap of the big pic..
http://img156.imageshack.us/img156/6...reengn6.th.jpg
Radaja, your temps do look a little weird and I dont think thats vid related. Do you have the AC pointed directly at your cpu? EOD has your same vid, batch and under water his temps are showing the same as yours but with .1 less volts. :shrug: Either way good job so far on the 500. :up:
hoss331, read post 934 i state clearly that i use an airconditioner.i have a dryer vent hose that blows very cold air directly into the intake of my computer.
Unless your chip is at the limit which is doubtful with such a low VID, sounds like your board is at the limit. Why don't you and remove 2 sticks of ram and see how far you can clock on just 2 x 2GB?
@Radaja - looking good so far. Ud3P is pretty good with quads, 500 FSB & 600 ram should be manageable on reasonable volts.
I agree for you viccan, take 2 sticks of ram out and try some more :yepp:
also viccan, if you get some better cooling like a Tuniq Tower, or the TRUE.. you'll be better off with temps.
My Q9650 at 4.0 and at 4.2 Ghz gives Idle temps around 30-35 depending on room temps, in the mornings it idles around 29c. thats with a TRUE cooler. get a new cooler over that 9700
I think I've found my 24/7 speed :up:
Stability tests:
http://img265.imageshack.us/img265/3539/ibtaiv5.th.jpg
http://img265.imageshack.us/img265/7505/occtaix8.th.jpg
http://img265.imageshack.us/img265/1...mpsaka7.th.png
3d stable:
http://img153.imageshack.us/img153/2096/06aas6.th.jpg
http://img89.imageshack.us/img89/144/am3awv6.th.jpg
I ran Intelburntest twice in a row and it passed both times, then I immediately ran occt 1hr and it passed. I also ran p95 for a little over an hour with no problems but stopped it because I don't like long stability tests. 3dmark06 and am3 were run twice as well.
Based on all this, it isn't necessary to run p95 for 24 straight hours right? My rig's in my bedroom and I wouldn't be able to sleep with the noise lol.
Ya, basically people say that OCCT for 1hr is like 10 hours of Prime95.
if you've passed OCCT, and IBT I think you're fine.. but common, you only have like 80mhz to go.. I KNOW you can get to 4.0 Ghz for your daily runs.
Thanks, I'll keep pushing :up:
Getting closer to where I want to be, and it doent look like 4.4 will be much of a problem on air.
http://i131.photobucket.com/albums/p...mapImage3b.jpg
ok, ive hit a wall here with my9650.i can only get 500x8 with mem 1:1. when i try to get them running 5:6 no go.does any one have a solid,stable template for 500x8 for the 9650?some thing i can build upon.most of the OC's posted with the 9650 are all 8.5x500 or 9x500,just a little to high for me at this stage.i have had some success but also ive been through three installs(corrupt).dont get me wrong im not asking an easy OC,but it would be nice to be able to see some others that are simular to my goals,voltage wise.the one for 500x9 are just to different for what im trying.thanks
This is my setting for the E8400 (Stable)
I will be getting the Q9650 soon
I would like to know if I can use the same setting or where to modify
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 450
CPU Clock Skew : Normal
North Bridge Clock Skew : Normal
FSB Strap to North Bridge : Auto
DRAM Frequency: DDR2-850 MHz
Dram Clock Skew CH1 A1 : Normal
DRAM Clock Skew CH1 A2 : Normal
Dram Clock Skew CH1 B1 : Normal
Dram Clock Skew CH1 B2 : Normal
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 5
Row Refresh Cycle Time : 60
Write Recovery Time : 8
Read to Precharge Time : 5
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
Write to PRE Delay : Auto
Read to PRE Delay : Auto
PRE to PRE Delay : Auto
ALL PRE to ACT Delay : Auto
ALL PRE to REF Delay : Auto
DRAM Static Read Control: disabled
Dram Read Training : disabled
MEM OC Charger : disabled
Ai Clock Twister : Moderate
Transaction Booster : Manual
Common Performance Level: 10
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
PCIE Frequency : 100
CPU Voltage : 1.36250v
CPU PLL Voltage : 1.51325v
FSBT : 1.2v
DRAM Voltage : 2.1v
North Bridge Voltage : 1.32525v
South Bridge Voltage 1.5 : 1.5
South Bridge Voltage 1.1 : 1.1
CPU GTL Reference 0 : Auto
CPU GTL Reference 1 : Auto
CPU GTL Reference 2 : Auto
CPU GTL Reference 3 : Auto
North Bridge GTL Reference : AUTO
North Bridge DDR Reference : AUTO
Load Line Calabration : Enabled
CPU Sread Spectrum : Disabled
CPU Configuration:
Ratio CMOS Setting: 9
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Intel Virtualization Tech: Enable
CPU TM Function: Disabled
Execute Disable Bit: Enabled
Load-Line Calibration: Enabled
CPU Spread Spectrum: Disabled
__________________
Rich Martin
Spec:
E8400 @ 4050 MHz @ 1.36v
Maximus II , P45 chipset
GeForce GTX 260
Corsair XMS2 DHX DDR2PC6400 (4 GB)
(2) Seagate 320 RAID 0, (2) 1TB SATA II
PS. Corsair VX550W
LIAN LI PC-60BPLUSII
Windows Vista Ultimate x64
Cooling: Swiftech H20-220 Apex Ultra
**update... took out 2 stick of ram and got it up to 3.92GHz but not occt stable primed for 2 hours no prob but quacks out after a min on occt?
Vcore 1.29v
NB 1.63v
DRAM 2.26v
SB 1.09v
FSBT 1.39
CPU PLL 1.632
All are auto except vcore need to keep at it but its almost 4ghz? I'll keep trying its bound to happen sooner or later I need a new heat sink anyone got a tuniq for sale, I've got 100% perfect ebay feedback and even baught products from members here but i need 100 posts to shop in the proper forum.. Bummer huh.. oh well thanks for all the help guys
I need a new heat sink / water kit you guys suck hittin walls at 500*8 thats nutz im stuck @ 3.9GHz its gotta be this zalman 9700 holdin me back Tuniq looks like the way
to go.. Or should I just hold off another couple weeks and go water ? Man choices choices choicews? BUY BUY BUY!! <---( I keep puttin that in my posts to save sony and the economy :)
dont get a tuniq..... they are old and lots of other coolers outperform it. get a Scythe Mugen2 or a Xigmatek 1284....
heres where im at now,still trying to work my way up there.http://i41.tinypic.com/20sg80o.jpg
radaja your chip clocks almost like mine...what vid and batch is it ?
my better OC's are:
4004(445x9) on 1,3315 vcore set on bios 1,328 IDLE
4050(450x9) on 1,35 vcore set on bios 1,33 IDLE
4104(455x9) on 1,3625 vcore set on bios 1,358 IDLE
4140(460x9) on 1,3725 vcore set on bios 1,368 IDLE
4185(465x9) on 1,3935 vcore set on bios 1,38 IDLE
All IBT 10 runs max stress on vista 64 sp1, the last one is my limit...
Cheers
Sergio
andressergio,my batch is L826A965 and vid 1.25
Anybody have Q9650 Batch L824B301?
Any good?
quick question about prime 95 and a quad core. is it normal when it finishes a test to go core 2,core 3,core 1,core 4.then after an hour or so its core2,core3,core4,core1.also why does it seem to be so far behind the actual time.for instance by the time the seventh test the actual time has been a little over 14 minutes?i did notice that when running 5:6 it seem to keep up with the time but 1:1 runs twice as slow.am i just being too picky here or is this a sign of clocks and volts not running in harmony?
Well guys the misteriuos things of hardware...For some reason I'm more stable on 8,5 multi at more FSB with less vcore than on 9 multi with less FSB and more vcore...
4123(485x8,5) MEMS 2x2GB 1213 PL8 MODERATE
http://img264.imageshack.us/img264/9...51213plem7.jpg
http://img264.imageshack.us/img264/1...pg/1/w1280.png
http://img145.imageshack.us/img145/580/capturazb6.jpg
