Thanks for contacting them, and that's a pretty good response. A little suspicious, but good none the less. Hopefully it'll set most everyone more at easeQuote:
We didnt find any batch numbers on those kits , even you can not know what week from CPUz
GeIL PC2-6400 Ultra 800 MHz CL4 are not Micron D9 any more.
http://img254.imageshack.us/img254/7...lkosci2dx4.jpg
I have these and they are not D9.
Me too, they are definately not D9. Mine can't clock higher than 830mhz. Even at 2.5v.Quote:
Originally Posted by xoqolatl
If these ICs really have dimensions of 12.5x10mm then it could be D9GMG or any other BN-x IC.Quote:
Originally Posted by mrhelix
If they are actually 12x10mm in size it could be any CB-x IC, including D9DCN.
It has either D9GKX or D9GMH. There were some rare cases of it having D9GCT, but you don't have to worry about that.Quote:
Originally Posted by NIZ
As far as I know only PC6400 Ultra Plus has D9. Your kit (which is just Ultra, without the Plus) has either Aeneon or Elpida.Quote:
Old PC6400 C4 ultra (before September ) used to be D9GMHQuote:
Originally Posted by r00n
Ah, I didn't know that. Haven't seen any of those, but I'll add it to my list after the weekend. :)Quote:
Originally Posted by kemo6600
Mine are week 27 of 2006 (according to CPU-Z) and are not D9. I guess all produced after week 27 are definitely not Micron, but we don't know which week was the last to use D9s.
anyone know if the current Patriot PDC22G6400LLK (2x1GB PC2-6400 CL4 kit) is Micron D9?
Yeah, I'd like to know that too... I'm going to buy a kit on Tuesday to replace those crappy geils.
just ordered some micron pc2 6400 cl5 for $68shipped, it should be coming at the beginning of next week
I'm looking for new mems, and my choise probably will be G.Skill 2x1GB F2-8000PHU2-2GBHZ. Anyone can tell me on what IC's are they?
People are saying about D9GMH, D9GKX and D9GCT - but which is on modules in the markets?
D9GMHQuote:
Originally Posted by Kean
thx kemo6600
HZ and ZX(D9GKX?) are in newegg in this same price - which one should i choice?
or other up to 300$
Cellshock? Team?
Both the HZ and ZX use D9GMH if you gona pick from those off course tack the HZ , another option is the crucial PC8000
I'm just about to buy 2GB of DDR2. The ones I'm looking at are these.
G.Skill HZ 800MHz £160.96 - G.Skill/Proven clocker
http://www.overclockers.co.uk/showpr...d=8&subcat=813
Cellshock 800MHz Micron £164.49 - 8 Layer's!
Ballistix 5300C3 £129.24 - Best Price
http://www.overclockers.co.uk/showpr...odid=MY-088-CR
Ballistix 6400C4 £158.61 - It's no difference to the 5300 right, not worth another £30?
I have a 1GB kit of Ballistix 5300C3 ATM the moment, which does 1.25GHz 4-4-4-12 2.45v so I'm swayed to get a 2GB kit. What do you guys think?
what about these??
they are buffalo value ddr2 800 5-5-5-15
http://img248.imageshack.us/img248/1088/buffaloty4.jpg
are they micron?
i only see that they are no elpida
EDIT: the ICs look similar to the ones in post 354.
the small white circe in each IC is too little to be micron, isn´t it?
CORSAIR DDR2 TWINX 2x1024 -6400 800@5-5-5-12 HS=Black XMS2 chips???
Any updates on these sticks?
I have some, 4.1 revs that will only do 935MHz so I highly doubt there D9, just wondering what they might be?
Promo's, Elpida maybe? :)
Edit: Found it out, there QIMONDA
elixer. looks like it's a different form packaging, but if you look at the writing, the codes are similar.
http://ramlist.ath.cx/ic/
and do you know how these buffalo will overclock? or any other elixir.
should I buy them?
I also see that in the link you post elixir is a bit rectangular, while these buffalo look like a perfect square.
maybe hynix that are more square and have 3 rows of info? also the first row is similar:
512821 in hynix and 512845 in buffalo.
is there any link about how do more or less every IC overclocks?
dont know,
if they had written D9GKX it would be easier to identify them and i would be happier.....LOL
http://www.xtremesystems.org/forums/...d.php?t=137583
Seems like they are SpecTek, found in trash bin near Micron fab :)
That is correct.Quote:
Originally Posted by s7e9h3n
No, the modules you're referring to with that URL are GeIL GX22GB6400UDCA.Quote:
The ones without the 'A' don't have SpecTek, but either Aeneon or Elpida.
Right, I see the difference now.Quote:
But they are crap nevertheless.
