As above if it is a single 12V rail then should be OK :)Quote:
I think the issue is the lack of amps... 28A on the PSU.. 30+A required by the GPU... :slapass:
I have used 550 Watt Powerstream with X1900XTX setup no probs at all!!
My Modstream seems to suck donkeyballs... My 12v line is 11.78v max.. 11.39 min and 11.59 average... :slapass:
This is my config:
http://img331.imageshack.us/my.php?image=dibujo28yb.jpg
Air cooling (default) and 1.500v.
Cooming soon Liquid cooling whith Maze 4 xD
Looks like you have'nt set the GPU fan to run at ~60% ~80% whilst overclocked and benching :slapass:Quote:
Originally Posted by Tello
Originally Posted by alpha0ne
How do you see that?
How much volts i can use on MVDDC, MVDDQ and VDDCI for 24/7 on stock cooling?
Can someone with single core run 3DM05 on 2700MHz and 700/830? PLEASE!?!
I will say 1,5 for vpgu if fanspeed is 100 %... Dont use temps over 75-80 for 24/7.. Memory are on stock here and the last one max 1,580
my absolute max is 1,5 on really good air around the stock cooler.. if temp reaches 75 her on the voltage regulator I will se artifacts in atitool
I have get the fan run 100% but 1.575v ...
Ok, but what about voltage for MVDDC, MVDDQ and VDDCI (24/7) on stock cooling?
I have 1,5-2,130-2,130-1,580 on mine for max OC...
Whats your max OC ??Quote:
Originally Posted by hot_fifty
712/841 fully stabil with 1,45 I think.. 1,5 was running to has for 24/7
i took the x1900xt to the store to put the v1 ultra (the memory solution they gave me) and they broke my card. it simply doesn´t work.
i don´t know if they are going to give another one..... there are diferent stores where i bought and where they put the V1 ultra.
if not, which model should i buy for x1900xt??? is HIS good???
the other question i have is that in the v1 ultra, i get some grey thermal pads for the 3 memories that are under the heatsink. have to be this pads in contact with the main heatsink???? are they good enouth for cooling????
please, help....
hi everybody!!!!!
i tried to install this cooler on my x1900xt and the results where very good. i install it with two funs too, that it´s an extra for temperatures.
but it has a problem. 3 of the rams can´t use the pasive heatsinks because they are blocked under the big tool (heatsink) of the gpu.
somebody know how to fix this???? i can try this::::
1º the package comes with some grey thermal pads to put on the top of the memories. this pads will touch the mail heatsink and get cooler with the extra fun.
2º in the 3 rams, 2 are kind of outside of the big heatsink and one just under it. so bend 2 of the pasive memories heatsinks to right and left, and maybe the center one just cut it to the maximum and put arctic silver 5 on the top for just to touch the main heatsink and get cool from there.
i already purchase it and i know it can give great results, that´s why i want to try.
thank you!!!!
This is my config whith liquid cooling.
http://img236.imageshack.us/my.php?image=dibujo6pa.jpg
Comming soon SS xD
i just bought the his x1900xtx iceq3. tomorrow i got it.
are all the x1900xtx iceq3 Turbo versions???
do they have to use special drivers from his??? if not, catalyst or omega 6.5??
thank you!!!!
somebody has experience overclocking the his x1900xtx iceq3???
how much did you get????
__________________
I have the standard his x1900xtx, got a very good batch i think. kan go 740-750/850-860 on original volts damn stable. Thats watercooled. :)
Very happy with that!
Thats an incredible card you have there licken :clap:
The Gecube X1900XT I am testing can only do 732 - 855 with 1.55v to the core :mad: :slapass:
well, i have it here.
i´m a bit disappointed with the his x1900xtx iceq3. it´s not bad, but i expected more from it.
the maximum overclock stable i can get is---
core at 1´5v---------- 711mhz----temperature-----76ºC load
memory at 2´140v----- 850mhz----temperature-----51ºC load
the memories are good and i´m happy with it, but from the core i expected at least 730mhz......
i´m using the atitool and atitraytool.
are the temperatures ok for only play games????
uhh this is poor result
i can run this freq. with stock cooler
and how much voltages do you get for you overclocking???
