OPB .. as far as vcore .. which do u trust besides verifying with a dmm .. the bios or cou-z / smartguardian .. i mean my bios reads like 1.62 but cpu-z and smartguardian read 1.552 ??
Afaik,I check all bios, mbm5, cpuz, system tools..Bios is about more than cpuz 0.02v
It doesn't matter you trust which one.
Update 4x512mb mix bh/utt ... ya mix them , no kidding:D
Will do 32m later. (these 4 dimm are not the best bh I got;))
http://img501.imageshack.us/img501/7...r520mix0dt.jpg
cpuz, take a look if 4 dimm got different brand :p:
http://img299.imageshack.us/img299/8...mddr5252fi.jpg
that at 1T or 2T? ;)
sorrt..little OT
could you explain me the drive strenght ? 7/3 8/2 :confused:
I've always used "auto" on those tweak
OPB, thanks for all the help with my ram/cpu/mb. tonight i figured out my problem, my ballistix are defective - i tried my friends ballistix and everything worked normally. Now i just have to rma these for new ones, or hopefully i can get a different brand - if newegg is nice to me :)
Originally Posted by Diverge
yeah i wish i could get a different brand of ram .. ditch my crucial ballistix for something else
From the looks of that spi time, I'd say that's gotta be 2t......Quote:
Originally Posted by ozzimark
Good god :)Quote:
Originally Posted by Onepagebook
You're giving me a reason to get the Expert :D
I couldn't manage to get mixed pairs of UTT working with DFI NF4.
Hope you are well after the disaster :)
Monge :toast:
Ya thank you Monge,
got so many to recover and move to new apt.
can't bench too long.
I will post some Team group TCCD 4dimm DDR600 and their BH-5 on next week.
Here is the 8m shot first.;)
This bios is based on Tony's Mod, Thank you mentor. Great work!!:toast:
http://img358.imageshack.us/img358/5...525pi8m3oz.jpg
JetJaguar, are you using the non-EPS 510SLI? If so, what did you do about the P412V from this PSU to go into the EPS of your Expert?
With the Expert, if all you have is a P4 connector, you can simply plug that into the upper half of the EPS connector.Quote:
Originally Posted by gummyz
Also, you can buy a simple P4->8pin adapter, I got both kinds (p4->8 pin, 8 pin->p4.....you never know when spare parts can come in handy) from www.performance-pcs.com
thanks stumpjumper, I was wondering about that. I'll save my reasons for not using an adapter to save face :)
I'm wondering tho if that may be hurting JetJaguar's o'c :\ btw I don't have the board but do have plans on getting it from all the good results I've been seeing so far.
im using the 4 pin ..
according to pcp&c it shouldnt be a problem with their psu .. so who knows .. maybe ill have to send it back for 25 dollars and get it converted to 8 pin
but my luck is just bad ..
Originally Posted by jetjaguar
Don't have to do that, I have one extra left., let me know you want that. Just pay me shipping is enough.cuz we are all got bad luck.;)
u have what ? an extra 8 pin adapter ??
is that what you are running ? or are you running the 1k psu ?
there seem to be a problem with my board. in BIOS and MEMTEST86 it is only showing as 3gig. but Cpu-z say 4GIG. here is a couple of picks for compare. I will do a mem test to see if it will go over 3.4gig. unless the is a limitation to windows.
http://img514.imageshack.us/img514/5944/4g5jl.jpg
on my expert i notice there is a tighter range for HTT than the other guys? 300fsb*3ldt won't boot consistently or will crash. 320fsb*3ldt has no such problems.
Why are you using 4 x 1GB sticks of ram ????, with media center XP :stick:Quote:
Originally Posted by Tamille
It is a limitation of Windows Service Pack 2....if you run Service Pack 1 you can see all 4GBQuote:
Reference here: http://www.xtremesystems.org/forums/...ad.php?t=78038
Ya,I am running 1kw now. check your PM.;)Quote:
that's the 3rd hardware I thought I need to get it with me when my neighbor apt caught fire.;)
I've posted a few times asking about the 8-pin @ dfi-street, and it seems that they suggest using it. I don't know if OPB is sending an adapter for you but can you let me know please :) - I'm stuck with the same PSU as urs and up in the air of getting the expert or non-expert version. Would like to know if it will make any changes to your o'c results
Thanks in advance
Just do the mod yourself ;)Quote:
does this mobo work with 4x512Mb 1T?!
From what they say it should work on stock sppeds.But the stability on OCing would get imposible even in low values.
OPB, any suggestions on 4x512 TCCD (G.Skill FF) at DDR600? I have found that I can only get into Windows with Driving Strength 1, and have tried Data Strength between 9 and 11; anything else won't work at all. I also can only use very large numbers for MAL and Read Preamble. I have been able to pass Memtest #5 and #8, but again Windows is incredibly unstable. Antivirus won't load, graphics driver won't load. If you have any hints I would be thankful.
