http://i20.photobucket.com/albums/b2...uardian308.jpg
My new HZ :D
DFI Lanparty Ultra-D ( bios 704-2BT-BigToe Mod )
HZ in the yellow slot @ 2.6 volt
http://img253.imageshack.us/img253/8718/hz25hh.jpg
http://img224.imageshack.us/img224/6922/hz34gd.jpg
Can you show your A64 tweaker screeny, and your settings???
:banana: Awsome, but you lost some performance, i can get 27s P1 1M at 275Mhz 11x275Mhz 3-4-4-8 1T 2.6v
screen A64 tweaker
http://img100.imageshack.us/img100/7264/a645dp.jpg
@fabry
nice set you got there:up:
Why idle cycle 16clks ?
What do you use for:
DQS Skew control ?DQS Skew Value ?Dram Drive strenght ?
I can't get my HZ:s higher than 262MHz on loose timings (actually 260-261 if I want to absolutely no errors :P )... I was looking for these to go onto higher MHz but i guess not. T2 doesn't give anymore herzes than T1. I am using 704-bta2 -bios. If i put FSB to 263 the memtest86 throws thousands of errors on test #5. I am not a master of these memory settings, but I've tried so many diffent settings :( I've tried different voltages too. I'll post a bios-screen of my current mem-timings later.
edit: These sticks were made in mid-april or something like that.
Help GS tech!!!Uh, just a quick question concerning the HZ,s
Are they Intel compatible?(875P 865PE) I seem to remember I read that they were somewhere in this forum,but I can't seem to find it now. been searching for days with no results.I bought them on a friend's credit card and away from my computer in hicksville.They have gone up $10. in the time I looked and ordered them at Newegg.(dumb of me I know) and no way to test em till I get home.(none of the local shops have anything that can handle ddr,just pc 133)
This is the best i can do for now..:(
My target is 280 1:1 but i feel is hard to reach it...
http://www.thelab.gr/attachment.php?s=&postid=395977
Try twtr 2 ,this should improve stability :fact:Quote:
Originally Posted by Dagalidis
Have you tried run Memtest86 ?
:slapass: Edit: man you post in the wrong thread !!!
You and adidassler posted here SS of other memory kit :slap:
No luck with twtr.Quote:
Originally Posted by Counter CS
Probably this is my wall...:(
http://www.thelab.gr/attachment.php?s=&postid=396199
Wait a moment, are sure you have G-skill HZ ?Quote:
WTF, 2.5-4-3-8 , is this at 1T ?»
Change to 3-4-3-8
Yes i have GSKILL HZ...Quote:
If i relax timmings the only gain i get is about 3mhz :confused:
Yes i know its strange but this is the way my ram acting.
I have the latest BIOS from DFI for my new DFI SLI DR board (Need to fix my signature again) :D
Well guyz, it seems as if my ram is hitting a max of 250-255 also =( I Was hoping for 270-280 grrrrrr.
Anyways I have a Venice week 17 @ 2.5ghz 1.5v in a shuttle SN95G5v3
Below is a screenshot, I have control over basic timings in BIOS...the rest are autodetected and Im trying to find the good combination of the other timings to adjust in windows. If you guyz have any suggestions for my timings to get higher, please post.
Thanks =)
Dram data drive strenght to L1 50%
Trwt 3
Twtr 2
Trrd 3
R/R QB 16x
Bypass mas 07x
Try that :fact:
I just got a 2GBHZ set and I'm having trouble getting them stable at 250MHz (let alone running them faster). They usually fail at the end of the #5 test on MemTest. I have a DFI NF4 Ultra-D BTW.
I used the bios settings on this thread: http://www.xtremesystems.org/forums/...ad.php?t=95044
I tried with 2.6v and 2.7v. Did I just get a bad set or is there anything else that can be causing the problem?
BTW, my rig is 54hrs Prime stable at 295x9 at stock vcore with a generic 2GB kit (that I already sold so I need to make this new set work). I also did a 24hrs Prime run at 300x9 at 1.45v so it seems my CPU is good.
Can anyone help me? I got to get my system working as soon as possible to crunch for Rosetta.
Thanks!
orange slot? i guess so!Quote:
Originally Posted by Daved+
try 7-3
clear your bios and do it again and see
Thanks :)Quote:
Originally Posted by guess2098
What do you mean with 7-3? Sorry, I haven't slept much last night, I was so pissed off with this set :(
I'm using the 704-2BTA BIOS.
That bios rev. was never stable for me on my SLI-DR if the timings don't work for you try using the latest official bios or the 623-3 bios. My set ran great up to 275mhz on the 623 bios but the ones you're using wouldn't even boot with the exact same settings. I had to relax my timings quite a bit to get it to boot into windows.Quote:
Guys, do you know if is there any difference between 0605 and 0604?
Thanks.
i meant dram level set 7-3 is good or 7-2Quote:
bios to me is using 623-1 or 702-1
My pair is not doing very well.
I have reached FSB274 with one of the sticks (they are 0601s), but the other seems to top at only fsb257 :(:(
Settings 3-4-4-8-7-14-2-2-2-3-3684-1-DD7-DS2-8ns-7ns
tried voltajes from 2,5 to 2,83v best seems between 2,65-2,75
Tried loosening timings gradually to 3-4-4-8-12-18-3-3-2-4-3684-1-7-2-11ns-6,5ns
tried dd-ds 8/2, 8/3, 8/4, 7/3, 7/2, 5/3, 5/2, 3/3, 3/2, 6/3, 6/2....
Only tested in orange slots.. there were a tccd on them before the HZs at FSB305, so they are good slots xDDDDDD
I think I'm using latest oficial BIOS (was from april?? )
Any idea or directly I look for another pair.
salu2.
I'm in the same boat, one of them is weak and will give me errors on #5 memtest, the other one seems to be strong.Quote:
Originally Posted by Dave338
Try with the yellow slots, it seems they work better with these sticks.
Saludos.
Tested yesterday, about same behaviour... The "bad" module fails SP2004 in two minutes at 265, and lasts a bit more at 260.
Finally working at 244x11 3-4-3-8 until I get another pair.
I need a pair that does 268 to clock the CPU at is best
salu2.
So we are in the same boat... What year/week are they? (first 4 digits on the serial number, like 0606)Quote:
Where are you getting them from?
