Ah so you undervolt them? You know at 7v they are exactly L1A specs?
Then that's the equivalent of what I have. I use them at 7volts most of the time but I like the flexibility of having the full 12v speed if I ever need it.
Edit: A somewhat failed attempt at better pictures, lower resolution so the blur seen in the first set of pics is less pronounced.
http://img287.echo.cx/img287/2822/kif24683ji.th.jpg
http://img287.echo.cx/img287/7895/kif24691ul.th.jpg
oooh zeebs, are those patriots I see in there? :D That's what I got as well assuming that is infact what you have, I only assume because of the red heatspreaders honestly.
Good guess, but it's Mushkin :D
bah! Fooled! I thought they had predominately black heatspreaders....hmm oh well
EDIT: man, what a moron I am, I just now noticed I put 'read heatspreaders' meant red of course : :stick:
Check out my first WCed PC HERE :D
zeebs the setup is very clean, love the look, kinda simular to my pc75 setup
shame your pumping into your res only fault i can see really, good job!
and turok, already posted i your thread, excellent work
Nice setup there zeebs. Looks cool.
Turok, all I have to say is my jaw dropped when I saw how beautiful that looked. Looking at ur pics and I thought to myself, "Now that's Xtreme..." Great job!
Usama aka Ferrari Freak
Yeah. My familly is a bit impressed too, even tho they dont know a thing about PCs :DQuote:
Originally Posted by ferrari_freak
They say Im a genius, because I can do all this stuff and Im only 16 years old.
Ive learned everything by research, reviews, and forums like this one.
Changed "Check out my WCed PC" to "Check out my first WCed PC"
Got those angle shots you asked. Check it out
I hope on makeing better PCs in the future :toast:
Turok
Hey! I'm 16 too w00t :woot: :toast:Quote:
Originally Posted by Turok
I'm only 13... :( Now if I can pull off something even close to that, then my family should be REALLY impressed. Been doing research for the last year almost every single day and I still don't understand everything going on at XS. Love those angle shots btw.
For the sake of having simplistic tubing, pumping into the res was a must.Quote:
Originally Posted by BAcon
Finally got my 2nd rig up :) my 1st rig with the pc75 is getting revamped again ;) here you go let me know what you think of it :) It's almost complete only a little thing left to do.
My setup is Dangerden TDX Brasstop, Dangerden maze 4 gpu acetal, and Swiftech MCP600
http://img.photobucket.com/albums/v9...Picture020.jpg
http://img.photobucket.com/albums/v9...Picture023.jpg
http://img.photobucket.com/albums/v9...Picture024.jpg
http://img.photobucket.com/albums/v9...Picture026.jpg
here“s how my WC is setup
That's huge! how heavy is that thing
nice work, idle, I see you found some water dye ;)
thanks zeebs :D
Originally Posted by CNCL
if u were refering to me my case is about 24kg
That is THE hottest water color I've ever seen, what dye is that?Quote:
Originally Posted by MegadetHCl
What case is that one, idle?Quote:
Originally Posted by idleuser
It is the blue UV dye from FrozenCPU.com, but I'm afraid the camera really did the trick on this one. It is nowhere as bright as in the picture, more like the following:Quote:
Originally Posted by HiJon89
http://img.photobucket.com/albums/v1.../37_resize.jpg
Sorry about false advertising, I would imagine you would need some serious UV illumination to achieve such luminosity.
Ah I see, thanks for the link :)Quote:
Psyche911: That's the kingwin kt424.
Ah, must be a custom hole in the rear then...
I'm wanting to move to a case with 120mm fans (front and rear), haven't found one quite right yet. Well, the Antec P180 might be but I don't think they'll ever release it. :(
