What fans are you using? I would think with some of the more powerful ones you would need a 3rd PSU just for fans...
God that's hot.
Now I will have to peek at this thread everyday.
For how long? I don't know.:ROTF:
Well being mains powered it puts no load on the PSU or motherboard, they move a MAL of air, AND if you do it right they run pretty damn quiet ... mounting might be tricky though.
0o0o0o so your planning a little thermalright tower town any plans for the chipset or pwm's?
You would think, I used to have 1190+ CFM coming through the front of my MM case with 9 133cfm Ultra Kaze's :)
back in a while. more to do..
If Movieman got the Extended Ascension (I it as an Ascension, but I can not tell if it is Extended) he could mount one (or rather place) on each side for a push pull configuration.
You may want to go for 120x38mm fans. Should be quieter for the same amount of air moved. I while ago I went through and looked at all of the 120mm Delta fan manufacturer data, and what it made clear was that thicker is better.
Pretty looking rig Dave. You must be beaming.
Looking like a pretty wicked rig. :up:
Bob
It's all assembled..
Just got to wire it up tomorrow and see what the baitch will do!:up:
Dude... I've spent last half hour reading all 16 pages and you still didn't make it work! Come oooooon :))))))))
I'd do a good old over kill for that case, one mo-ra2 rad to cases front panel and one to the top :p:
That would be some kooling power :D
But before this goes off topic too much: :slobber::slobber::slobber::slobber::slobber:
Ran into a little glitch at 2am, had to mount HS "sideways", then slept like the dead and last night here and now huge rain storm..
BUT the good news is the sleep gave me a solution that will get it the way I want it. Should fire it up in a few hours after I suck down some coffee and get human.:D
I read about the storm in newspapers, again 0,5 mil without electricity? Hows your generator doing? :)
......searches ebay for 40kva generator to power this ftl machine :rofl:
