impressive clocks moonman. Such low vcore for those clocks!
this is on a SS.
http://www.overclock.net/gallery/dat...piphenomII.png
http://www.abload.de/thumb/1hprimec3-164kt.jpg
0945EPMW
4ghz 1,456v 1,4v NB
More superpi lovin:yepp:
http://img412.imageshack.us/img412/9...55c3spi32m.jpg
http://img94.imageshack.us/img94/8296/pii955c3spi1m.jpg
That's it for water cooling. After the new year I'll put it under LN2.
Awesome CPU-NB speed on that 32M run for just watercooling moonman!
¨whau, nice watter
Well, it's kind of cheating, water temp around 12 °C :D
Getting Vanyage higher,
965BE 4.2ghz 2800NB
single 5850 1000c/ 1259m
Orb Compare
http://3800z24.info/Phenom/965/vanta...-2800-5850.jpg
OK managed to get 4400mhz SuperPI done.
Ambient temps around 23C
http://www.erraserver.com/oc/4400mhz_thumb.gif
Here is my first C3 OC on LN2
thread here > http://www.xtremesystems.org/forums/...d.php?t=242063
:up:
http://img97.imageshack.us/img97/923...uperpiiiii.png
Wow dinos22 that's awesome! Will we see sub 10s SP1 from you? ;)
maybe u can get +100MHz at CPU and will see :)
The dreaded AMD 1920mgz wall :confused: but i finally figured out how to get to the wall, could never get past 1880mgz, keep pushing see what happens. Maybe that AMD master will give me a tip or two.
Well i did a quick 1m runs, i can get 1928mgz but it crashes on the 10th loop :mad: any tips ? i will do some 32m runs to, but i think heat might be a issue im on air, and its only 50 degrees out. I will turn up the cpu speed some to. I tried to tighten up my timings but it crashes before i hit 1900mgz. I wish i could run cas 6, but thats out of the question with these sticks, and this speed.
Tips for mobo's is mobo specific.....
I no longer have a working MSI, my board that died on water is in RMA atm, my ln2 board lost a dimm slot on air.......I trashed it.
I have heard the MSI can blow, and take cpus with them. Im still learning about this board, just havent had the time to dedicate to learning enough, but i have never gotten my cpu over 4.350, just my lack of experience, but i will keep trying. Now i have discovered the clock dial on this thing, helps alot.
To go past the 1920 wall on the msi mobo just use 3-10 divider in mem settings aka 1333mhz and raise the HTT then u can go further i went to 1940mhz with my Gskill Eco 1600mhz 7-8-7-24 mem last night but with the 1-4 divider aka 1600mhz i couldent go past 1800mhz at same cl and volt
Well i think its a wall 1920 on most boards and chips, but Chew just destroyed it, so who knows how high it will go, i bet 2000 is doable. Hey thanks for the tip, i will try that, i could use all the help i can get :up:.
I tried the 3-10 and i got a few more mgz but not much, i think i hit 1930mgz, so not alot of gain, but thanks for the tip. Was your 1940 1m 32m stable ? or just suicide ?.
It was 8m stable 1950 was sucide
that must be another day have just switched to the new gigabyte ud5 board but wil post screens soon
I cant get it stable past 1920, i have the GTS 2000 cas 8, you have the ECO gskill 1600 cas 7, and they go that high, wow, looks like those clocks better than my GTS, i cant add anymore voltages , so im guessing you have to play with drive strenghts to get past 1920mgz :shrug:
