What...no jokes about me killing mobos :p:
on a lighter note
i am really starting to like my board
if she can repeat this with a 25xmulti now that would be nice :D
http://img401.imageshack.us/img401/7...t32msuperp.png
maxmem will stabilise at even higher clocks ;) but i dont think my chip has the legs to run that high on LN2 :)
i can only imagine how high 2:12 or higher ratio will clock this RAM.....scary :banana::banana::banana::banana: hehehe
very nice Dino :toast:
i dont know why but my board is acting a bit odd when it comes to CPU PLL
when i flip that xcool switch thing selecting 1.8v in bios still results in 1.35v which is normal apparently but i switched it back to default position and i still get 1.335v on dmm and it shows nothing in windows :rofl:
havent seen anyone take screens with a volt blanked out like that
i dont care though
the board works ok lol
btw all the volts are checked with DMM :)
why do you ask?
ah nice
good to see man :up:
Should be included in the manual :)
Hey people! I have a few question. Im going to buy a Classified but I have doubt in wich one I should buy, the 760 or the 759? I know the principal difference is that the 759 has de NF200, but there are any other differences? Wich would be the best for OC and in your personal experience wich one gives you the best result and less troubles in general?
Also... a Prolimatech Megahalems can fit in?
Thanks for all! When I get the mother I will post some results :)
PD: Sorry for my bad english.
What Different 759 & 761 ?
Having trouble getting my 920 stable at 4.3GHz.
It went real easy to 4.2GHz, but 4.3 has been a problem.
every time i up it to 4.3 it will prime for a couple of minutes, but every time i get a BOSD with the error "a cpu interrupt was not received on a second processor in the time allotted"
My max temp rages from 62 - 72 when stressed depending on the core.
I have tried upping the voltages a couple of notches, but no luck.
This is my first i7, so i am learning as i go. I figure there is something easy i am missing that is holding me back, any help would be appreciated.
I have tried upping the voltages to:
CPU Vcore = 1.2375
ICH Vcore = 1.1
QPI PLL = 1.2
IOH Vcore = 1.2
CPU VTT = 1.375
here is stable at 4.2GHz. (RAM is relaxed to eliminate any problems with it)
http://71.11.166.100:81/images/computer/4210_linx.png
Thanks,
http://www.pctunerup.com/up/results/...6_DSCN0592.jpg
COMING SOON....:D
Hello everyone... I've just about decided to get one of these boards, but I want to put it in my current case designed for standard size ATX boards. The classified is an EATX board but it appears it's just a bit bigger than standard ATX boards. Will the screw holes line up in the case assuming the board would physically fit?
Thanks,
Chris
Ahh, well, ok :doh:
I thought it was something more complicated than that ;) Why would it come lose like that all of a sudden if it worked before though, or I guess it could have just been fluke it did work before and eventually from moving and bumping the board it goes a bit loose.
By the way, do you have any updates on an upcoming BIOS?
Whats going on? I'm due to receive my x58 Classified along with my i7 920 tommorrow and I've got a couple of questions...
First, will the red sata ports (or the ones that are on a separate controller) run a Raid array? are they bootable?
Second, and I've scoured the internets for an answer to this one, will this board run crossfire? I know x58s are supposed to sport both but EVERYWHERE i've read they only talks about 2 or 3 way SLI, or SLI + physx...I just need to know if that's a feature this board supports. It's going to be a minute before I can cough up the cash for some 285s and I need to know if I'm in for some disappointment when I plug in a couple of WCed 4870s tomorrow.
Thanks in advance for the answers...and KaptainBlazzed, nice etek in the sig, more of a DM/PM guy myself but regardless, not a bad setup. Dirty south means SE USA...played any CFOA?
On the first, I don't know for sure since I do not use those ports but yes at boot the JMicron controller tried to detect drives so I would guess whatever is connected there should be bootable.
On the second, yes, the board will run CrossFireX. I ran two 4850's on it just a few days ago for some testing. X58 natively supports CrossFireX.
Guys,
I have a 760 with a 920 C0/C1 chip (quite a cruel joke, btw - just bought it and quite some bad luck to get a C0. Didn't know importance of D0). Trying to get to 4.2 eventually, but at 4.0 for the moment and stable (IntelBurnTest maximum burn with many runs, superpi, benchmarks, etc.) except one thing - sometimes, like entering a game, a USB (such as my G15 keyboard) will disconnect and reconnect. This does not occur at stock. I suspect it could be due to one of my voltages being low. Please help me figure out which setting to adjust to stop this from happening, as it sounds like a slight bit of instability.
I filled out the template with all the settings just so you have all the information. Thanks for any help you can give on this issue!
Mother Board ( EVGA X58 Classified E-760)
Drivers (Newest from EVGA site)
Bios ( Newest from)
CPU ( 920 C0/C1)
CPU Cooler ( Cooler Master V10 )
Memory ( Corsair TR3X6G1600C9 XMS3 6 GB 3 X 2 GB)
PSU ( Corsair HX1000 )
GPU ( GTX295 )
Drivers ( 185.85 )
Operating System ( Windows XP 32-bit SP3 )
Frequency Control
CPU Clock Ratio ( 20X )
CPU Host Frequency (Mhz) ( 191 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( Auto )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature
Memory Speed ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 800Mhz / 2:6 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 9 )
tRCD Setting ( 9 )
tRP Setting ( 9 )
tRAS Setting ( 24 )
tRFC Setting ( 74 )
Command Rate ( 1t )
Voltage Control
EVGA VDroop Control ( Without VDroop )
CPU VCore ( 1.375 )
CPU VTT Voltage ( +150mV )
CPU PLL VCore ( Auto )
**IOH PLL VCore ( Auto )
DIMM Voltage ( 1.62V )
DIMM DQ Vref ( +0mV )
QPI PLL VCore ( Auto )
IOH VCore ( Auto )
IOH/ICH I/O Voltage ( Auto )
**VTT PWM Frequency ( 250 KHZ )
**CPU PWM Frequency ( 800 KHZ )
**CPU Impedance ( Auto )
**QPI Signal Compensation ( Auto )
ICH VCore ( Auto )
*PWM Frequency ( Not Used on Classified )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( 4.800 GT/s )
OC Recorvery ( Disabled )
