It looks like it is freaking humongous, thats a lot of crap to cram inside of a case
Crap?!?!
I am sure that he means "stuff to cram inside the case" :)
Quick question on cable management. On your renderings, you don't have a PSU inserted into the case, are the slots between the MOBO and reserviors large enough to accomodate sleeved cables. Do you expect enough room to feed power cables to the GPUs while also running tubing from the bottom radiator? Everything else I like, it's big but its a beauty.
Thanks for the compliments. There is plenty of room for cable management. There are slots on both sides of dividing sections. The ones nearest the motherboard would be used for the cables and the others used for the tubing.
Here's a couple of animations, so you can compare my case design with the SilverStone TJ07 and the Lian Li V2000....
http://i277.photobucket.com/albums/k...cox64/TJ07.gif
http://i277.photobucket.com/albums/k...ox64/V2000.gif
holy jesus christ :O, for the love of god, THAT THING IS HUGEEEEEEEEEEEEEE.
Watercooling freaks rejoice :)
I'll buy it!! :) Tons of space for everything and anything! Lol, a case that's actually bigger than the Lian Li V2000!!!!
Mike
Its clean lines remind me somewhat of the new FT02 coming out from Silverstone. very sick case.
Mick, some questions for you.
1) How did you import the file from Sketchup to Kerkythea? what file type? I haven't played around with it too much yet...impatient LOL!!!
2) I have similiar designs made out of Acrylic, although not quite as big and not enough room for rads on top. Im talking 24" x 24" (600mm x 600mm) designs. I would love to take a crack at making this masterpiece out of acrylic when I get the chance... if you will allow me to? This time around it won't contain acrylic rod or tube.
I have started my new venture into case building out of Acrylic, laser etching/engraving services, custom case fabrication. Eventually I hope to move into metal as well. Got to start somewhere!
You can find where I started here: http://www.evga.com/forums/tm.asp?m=100586089
and here: http://www.evga.com/forums/tm.asp?m=100755309
and finally here: http://www.evga.com/forums/tm.asp?m=100738124
I am at a pause right now as my laser cutter is set to arrive in 30 days.
You have an awesome case design and excellent skills with sketch up and kerkythea...my hats off to you!
Thank You,
Kirk (Gone Cruising)
Yes, it would all be done myself.
I just noticed...your a few miles north of the border from me!
Fantastic build! You deserve every success in your new venture! Your SketchUp skills aren't bad either! :clap:
Thanks for the compliments! SketchUp models are actually exported from SketchUp into Kerkythea. There is a plug-in for SketchUp available on the Kerkythea website.
Feel free to PM me if you have any other questions....:up:
Thank you! and I will definitely be asking the questions!
So no case company is interested? Truly amazes me!!
Did you find out how much that prototype place will build it for? I would definitely donate some funds for you to get it made and perhaps some other folks as well. Imagine if everyone that viewed your masterpiece donated $20 to $30. Then once the design is finished and you have all the correct specs, you can find a shop to build it on demand...someone wants it, then they pay up front to have it built. Just a thought!
Thanks Prada! It may be a little too big for Acrylic, maybe not, but in time I'll purchase the right metal working equipment and build them for Mick and I'll send him royalty checks for his design...
Well start another thread!
looks good, but I am still 100% pure brushed BLACK aluminum :D
Aluminium +1
Wow. What a great way to spend a half hour in the middle of the night. I really like this case. I think the paint job could make this case work in steel - the two tone black and red would look great.
Really nice.
