Just try to fine a stable point for PL9 I think this should be good for 24/7 Voltage But I fail to got stable above 533 FSB 1:1 DRAM@PL9 Setting....:mad:
Any suggestions on what ram has been playing nicely with the EP45-UD3P?
Corsair dominators? Mushkin?
Thanks!
I switched to patriot Vipers 8500 and they haven't missed a beat.
They're on again for 59.99 after rebate http://www.newegg.com/Product/Produc...ory-_-20220315
gskill seems to be fine
Which model G Skill?
Sucks that they only have 1 pair of 2x2GB listed on the QVL...
Just tried F6d BIOS and use strap 400 1:1 and it work fine like always. Not sure about strap 333.
The S3 mode still doesnt work at high frequency BUT it did wake up at 4.1Ghz with Q9650 compare to 4Ghz with F5 BIOS. After 4.1Ghz with Q9650 it just fail to wake up no matter what setting I put in.
New UD3R beta bios out too??
You might want to try it in single channel mode. Supposedly they work fine if you do so. Im hoping that one of the new BIOS updates will fix it...
I bought mine from Newegg, and I dont think they let you return them unless you pay the 15% restocking fee.
I think that I might try the Corsair Dominators next if these dont end up working...Newegg reviewers seem to not have a problem w the doms.
Well I am running a set of these and they work just fine for me on the UD3P.
http://www.newegg.com/Product/Produc...82E16820231209
I should have just bought the Dominators or Mushkin :-/
Those look pretty nice. I was gonna go with 1066 since the price dropped recently.
Anyone got an opinion what the best ram for the UD3P is?
I've seen some crazy marks...but thats above my head.
hello guys, :)
this is my first ever gigabyte board, quite amazing i might say:up:
but ineed some info regarding easytune6, say if i click "save" on those voltages and core settings will it be saved directly in bios? or i have to set it manualy after i found my sweet spot?
thx
asap
EDIT: ..will change my avatar soon :p
i think gigabyte is just renaming the same bios,s or just putting in new mem codes for the ram that wont work for the boards did any one notice a real difference with any of the new bios,s
@Void Warranty, Dazog was merely pointing out that F4 was the final version of F4A.
guys my dominator will only work in single channel. i am running the f4 bios. Is there anything I can do to get it to work or just RMA it. This is my second pair of dominator that wont run in dual channel.
I been checking the forums for popular 1066 kits and it seems there are many problems getting 2 2GB sticks to work in dual channel mode.
Sucks cause this board seems to be real nice otherwise.
Wish GA had a support forum.
My Corsair ddr1066 2x2gb work fine here with ud3p and every bios....Try check both stick with memtest or try different slot....if no go probably the motherboard itself.
Gigabyte Support Forums (click) Dont forget to put your systems sig if you expect people to help you.
Probably you have sort it out by now...manually in BIOS after find the good spot in ET6.
I noticed a HUGE difference with the F5 official from the stock F4 on my E8400.
At first the board was sketchy doing 4.2ghz on MCH 1.38 and VTT around 1.40.
With the F5 it's stable @ 4.3ghz MCH 1.24 and VTT on 1.300 with 1.37 vcore.
http://i58.photobucket.com/albums/g2...3ghzstable.jpg
http://i58.photobucket.com/albums/g2...lFTTstable.jpg
Stopped the Small FTT early so I can throw in the Q9550 I just bought :)
I literally just got my EP45-UD3R a few hours ago, but I must say I'm quite impressed with it so far. Just looking at it you feel you really got something for your money. Once I had it running and ran a quick OC, I knew I got more than I paid for.
http://img296.imageshack.us/img296/8281/nicekd0.th.jpg
did any one try to install ubuntu on this board cause mine wont do it
