cheers, thats what I was looking for...I'll have to do some messing around tomorrow, make sure either A) my tools will work, or B) I can reliably use the sanded down pin made
Mr.Miyagi used a murderMod Psychopack (in Germany from MDPC-X called Konjunkturpaket / Götterpackung / Familienpackung). 3 Sizes of Sleeve and 4 sizes of heatshrink make it possible to play and do transitions from individual wires to big bundles as seen on the photo.
The energy you wasted complaining and trying to be a douche bag could have been used in a positive manner with a simple answer, it's forum that's what its for, many don't have the time to read 16 pages of mix junk like the one you just produce, be kind and productive.
most of the info in regards to it is on page 1 anyways...
c'mon now, you don't have time to read 16 pages but you have time to sleeve every wire on your psu? it is at least a 3 hour project and maybe more since you haven't done it before. i know this is the internet and all, but you asked for help in a rude manner and then start calling people douche bags. what kind of reception do you think you'll get? instead of "give me" you can try "can you" and then maybe you'd get more help. damn, i aint your mom but you're the one asking for the favor here. manners much?
anyways, http://www.murdermod.com/
i want to know if enermax would do anything if i sleeved my cables or is better to just get extensions and sleeve those?
the other option is at ppcs they sell cables that are on the modu 82+ which are universal cables (as i think) which work with modular connections
http://www.performance-pcs.com/catal...ducts_id=23810
http://www.performance-pcs.com/catal...ducts_id=23807
i officially hate you all sooo much, iv sleeved the 8pin cpu power, and its extender, as well as all the front panel cables on my cosmos black label, and now my fingers are a cluster :banana::banana::banana::banana: of cuts, gashes and bruises... also my fingernails are destroyed
im sleeving a Corsair HX1000, which (i tested this) is about 1000x more difficult to remove the pins from than any other powersupply
(i tested my antec TPQ-1000, some generic crap, and a 600watt coolermaster, all of which were super easy to de-pin)
anyway pics of where im up to below...
http://i40.tinypic.com/ne9ans.jpg
http://i43.tinypic.com/2it6fck.jpg
http://i40.tinypic.com/w63wx.jpg
http://i42.tinypic.com/es2fpd.jpg
I feel your pain, MulletBoy. Courtesy of my HX1000 ...
http://shazza53.smugmug.com/photos/4...85_hcwEc-S.jpg
I must admit - I am a little curious as to how it is that everyone seems to hurt themselves while sleeving? :shrug: I have never cut myself with all the sleeving I have done...
The corsair power supplies are that hard. You have to pull 'til you get almost blue in the face. At one point you will not care where your hands are so when it finally lets go the pin will skrape your skin on the other hand with full force.
ya, in order to get a good enough grip you need to curl your index finger around the back (end that the cable pulls out from) of the connector (which has sharp corners btw)
then when you pull with all your might and the pin comes out, it latches through the joint in your index finger like a fishing hook, i also got similar cuts on my thumb too when the connector slips out of my grip and the corner of that rips through my thumb
Yep ... that pretty much describes it. It's the pulling that ends up with the cuts. My problem was when I used staples for the 24-pin and 8-pin removal on the Corsair. I then switched to the Sunbeam tool for the PCI-E cables, had better luck with that - but I also had more practice by then :p:
I never had to use so much strength. I think many of you guys are ham fisting it.
My first few times was more brute force but once I nailed down the technique, I realised that no strength was needed.
In fact the callouses I get on my thumb are from all the heat shrinking as I keep having to strike the lighter with my thumb. :D
Those cuts are made by using stable wires i guess, with the proper tool i dont think you can cut your self even intentionally. Im still learning on how to effortlessly remove the pins using the sun beam tool.
hmmmm - I have sleeved both a silverstone and a corsair unit using staples as well as a pin remover and neither one was harder than the other and defeinately did not result in cuts or anything....
However I think I am going to invest in one of the molex tools that Charles has on his website for my next sleeving attempts.
I think that you cant do things which you wouldnt be able to do with all their basicaly requeriments they need. I think the message is clearly enough.:)
By the way.
I would be interested to see if anyone have sleeved their cables with BLUE (no light blue, just BLUE) or ORANGE (or if there exist any colour like the copper tone)
If someone have some in that way, or have any pictures, I dont bother if who show the material is not the owner, Just because I couldnt find sleeves with those colours and I would like to see if they match.
LOL ... I did get better at it. Actually found pushing the pins "in" before trying to pull them out helped a lot. I am absolutely a klutz, so people shouldn't be scared off by my experience.
And ... theseeker used gloves ... they looked hilarious, but saved his fingers!
the tool can be found here
