First ,,
Set your Ram timing to Auto with 2T Enabled then select 1068....
If that works you can lower your timing after.
Ganged mode usually is the fastest and most stable,,
look for a setting that has Ganged Mode..it will be defaulted to (AUTO)
****Set it to Ganged****..
If that dosnt work then try Unganged..
Note: IMPORTANT
Make shure you Ram volts are set to run 1066.(factory spec of your ram volts)
Make shure your using yellow Ram slots for dual channel mode .You may need to raise your NBvolts some for 4gigz even though your usin two sticks..It puts a litte more load on the IMC/CPU when running 4g's.I only add volts if its not stable
