:welcome: To XS :up:
some cards may not do 710 with only 1.2v not all cards will act the same. try dropping back to 700.
Sorry for a kinda OT, but has anyone had problems with the settings not sticking? I've flashed my 4870 twice now, the second time I changed all the values to 825 / 1150 respectively but now it just sits @ 500/900 or something pathetic like that :\
Any ideas guys? :)
Sheesh, I'm not sure. When I enable overdrive again I can set it and it reads correctly in gpu-z but still limited to only 790/1100 :(
I try to push de Vgpu to 1,263 and the same history, it is impossible to start 3dmark06. You put some pictures of my bios modified, ¿ Some tips ?
Or is it possible that my card ( Asus HD4850 ) can not be overcloked ?
http://img112.imageshack.us/img112/7...9087gx0.th.jpghttp://img77.imageshack.us/img77/902...1926zi4.th.jpg
Gracias , Thanks.
Ive used a custom bios to set 1.263v (which is the same as setting 1.2v i assume). The most I can get is 730mhz on the core. I am running an s1 with a 120mm fan with temps never going above 50C. Before this voltage increase the highest clock speed I could get was 680mhz.
Jzsteam, you should unlock all of it and change the voltages for clock info 7-9 as well. Also, use furmark stability testing to get the highest stress on the card.
Heres what I'm currently using
Thank you for your help,¿ now this is how the image is correct ?
http://img364.imageshack.us/img364/5...1572vl3.th.jpg
And as I change the values of fan ? Look the image of my fan settings, I am not leaving all options.
http://img386.imageshack.us/img386/7...4923pj4.th.jpg
Thank you ghost101, now works very well whit your help, tomorrow change fans by de Coolink GFXChilla and testing in the Crossfire
http://img398.imageshack.us/img398/7...9067mt7.th.jpg
my card is pretty good in the respect that I got it up to 700/1100 with no problems and can probably go higher if I wanted to on stock voltage, just wondering, what's the pencil mod for the 4850? Last I heard changing the voltage in RBE doesn't get you very far and that you need a hard mod instead
Im all stock, voltages and coolers, and i am at 725 / 1150
I think its very nice..
Although i cant run 3dmark too normally... but just add this to the shortcut and you can:
C:\Programas\Futuremark\3DMark06\3DMark06.exe -nosysteminfo
I would like if someone helps me to do some mods in the graph...
i have one 20kohm resistence..
Hey guys been awhile since i have posted here.
I am getting a HIS 4850 and all i want is similar speeds as the 4870, can we just not flash it with a 4870 Bios?
Or
What do i have to do to get it to the speeds of the 4870?
I see Guru has a HIS card and Bios uploaded, can i just flash the card to that Bios and do nothing else?
Will i get 750mhz and whatever on the memory which Guru has set?
Should we wait for the Overclocked Versions of these cards to arrive and flash the bios with the overclocked Bios?
Thks
no you will wind up with a 200 dollar paperweight, aside from using a similar core these cards have nothing in common with the 4870. the 4870 has GDDR5 memory VS GDDR3 for the 4850, they have different chips controlling speeds and voltages also.
you could wait for some 4850 OC editions and flash to their bios or use RBE 1.1 to set the clocks you want and do either a pencil or hardmod.
jimmyz
So if i flash with Guru's do i have to do a pencil mod?
The bios he has uploaded is the 750mhz i downloaded it and have it currently opened with RBE, the only thing i would change is the fan settings... but to what SCALE should i do?
ghost101
Ok i may have missed it, but did Guru actually do a pencil mod for this uploaded bios?
His is a HIS 4850 and mine will be of similar product/manufacturer.
Ok i suppose Guru is needed here to explain further for me as if he did so before or after this bios.
Guru where are YOU???? .. LOL
Ok i read this ... By Guru
pencil modding is pretty easy...but you can get 1.2v with a simple bios flash and that would allow you to go to 720-750
HERE:
http://www.xtremesystems.org/forums/....php?p=3112051
Hmm i will still wait for him to post before i do anything.
Yep, thats exactly what people have been doing. Youll have to edit your bios to give 1.2v and then attempt to find the highest core clock you can get. Like I said before, not everyone is able to get 750mhz. Its precisely what jzteam was doing on this page. He was only able to get 710mhz while I got 730mhz. I cant remember if gurusan got 750mhz purely via editing the bios though. But even if he did, you want to gradually move up towards 750mhz flash by flash. Jumping straight to it may simply cause instability whenever the aero interface or something causes 3d clocks to kick in. I suppose if you use atiflash this isnt much of a problem though.
Over the past few days I've flashed so many variations of 4850 BIOSs (no pencil modding, etc.) that my eyes almost started to bleed. I've taken the voltage up to 1.2, core from 625-720 and memory from 993-1050. As I ratchet up the numbers I also increase the cooling. Regardless of what I tried I simply could not get EITHER one of my two VisionTek 4850s to pass every test completely artifact free!
For instance... in 3DMark Vantage (Extreme mode) during the first test if I watch extremely closely I will notice a single artifact (looks like a 1/2" square that flashes once for a second in the middle of my screen) during the part where the girl jumps into the boat and drives it out from under the camouflage cover. This happens even on stock settings. Am I just being too anal here? :shrug:
My system :
Mainboard ASUS P5Q3 Deluxe
CPU Q6600 @ 3.78GHz
RAM 2x1GB DDR3 Corsair CM3X1024-1333C9DHX
ASUS EAH4850
Windows Server 2008 Enterprise SP1 32bit
My system's picture
http://forum.amtech.com.vn/attachmen...1&d=1215231778
3DMark Vantage Score of Asus HD 4850 @ 815/1111
