nope, fan spacing is 15mm
How hard would it be to get it to fit?
should be easy, I know someone who fit the PA120.3 such that the front fan hole was used correctly and then he just drilled holes (or widened the holes in the mesh) in the right place in the mesh for the other fan holes.
He didn't fit every screw though, just enough to hold the rad in place
do you guys think the hydrx( uv green) will be a good color in this case?
Well im almost done with mine, ill update the pic when im done, i got 1 thing left to do.
http://i248.photobucket.com/albums/g...d/DSCN0147.jpg
someone told me......bump how to put dust filters on haf 932
I'm probably going to swap the 230mm side door fan for 4x 120mm Noctua fans. Can anybody please tell me how I can wire the 4 fans together (using an adapter or whatever) to plug them directly into my Corsair HX1000. :)
I'm trying to keep the damn NB temp down without getting into watercooling at the moment.
I have used my imagination and fitting an additional Noctua fan that blows onto the NB heatsink and RAM slots. Sadly this has only reduced the temp by 3-4 degs, temp now sits @ 40 deg.
Also thinking if it's possible to fit my HX1000 PSU at the top of the case instead of at the bottom. This way I could have 2 more fans in the floor.
Can this be done?
Thanks guys...
Her is my finished product, my only complaint is that it weighs a ton!
http://img.auctiva.com/imgdata/1/1/3...35926929_o.jpg
http://img.auctiva.com/imgdata/1/1/3...35926975_o.jpg
http://img.auctiva.com/imgdata/1/1/3...35944927_o.jpg
http://img.auctiva.com/imgdata/1/1/3...35781695_o.jpg
and Pre I7
http://img.auctiva.com/imgdata/1/1/3...35781325_o.jpg
how thick are the side panels of this case? thicker than the aluminum in the LL V1000? do they bend easily? how about compared to the centurion 5?
anyone want to buy my LL V1000B Plus?
certainly not thicker than v1000 panels, they are the thickest panels ever put on a case lol.
Hello XS! I was observing this wonderful forum quite a long time so it's time for me to finally "enter" :)
Here's my share to the HAF owners around the globe ;)
http://img220.imageshack.us/img220/2623/61810701.jpg
http://img220.imageshack.us/img220/5579/33888643.jpg
http://img228.imageshack.us/img228/3654/67848708.jpg
http://img232.imageshack.us/img232/4007/43698027.jpg
As You can see I'm using 4 120mm fans instead of one big & ugly 230mm. I "joined" the 4 fan cables with soldering gun :D Basically You have to brutally cut off 3 fan connectors and solder the loose wires to 4th fan connector - black to black and red to red. I didn't soldered the yellow rpm ones. Then just connect the connector to Your psu. You can also use sone fan cable splitter if You like:Quote:
http://www.caseking.de/shop/catalog/...UAD_073_1g.jpg
Just ordered my HAF today, guess the consensus was that it was generally a better case than the Antec 1200.
i would've ultimately preferred a Lian Li Full tower, but i just can't afford it in this recession. their quality is remarkable.
we'll see how this case compares in quality to my LL v1000
Sweet..welcome to the club. I just ordered some red sound activated lights for mine..trying to pimp it a bit now. :-)
Anyone going to the soup line for supper since we are in a recession? :shrug:
From one of the great guides in the forums, I'm pretty sure you do not solder the yellow ones because then it gives you the RPM * How many fans you have. I wish I could find the guide since I used it to connect my rad fans together.
Huh? :ROTF:
for those who r watercooling their HAF, which way do youguys have ur barbs pointing down from? the drive bays side or the rear side?
Greenfox....could you post some pics from the top please so we can see the mods. required to fit the PA120.3 ?
Thanks man!
Sure I took these with my iPhone sorry for the bad quality!
http://i6.photobucket.com/albums/y24...o/IMG_0010.jpg
http://i6.photobucket.com/albums/y24...o/IMG_0008.jpg
^^^ Great....Looks good, so just two extra holes drilled in the front bit, any under the cover ?
No mods to the PA120.3 ?
