Is the Vcore on 0906 and 0603 the same when the Voltage Damper is disabled? Or is the Vdroop on 0906 even worse than on 0603?
should i apply these mods. or the one Resistor from the topic start
and how do you do these mods, just a 2HB pencil, en color it black from left to right?
and probably buy heatsinks for my upper mosfets as well i supose;
my guess would be that we can, however somebody needs to try it.
i'm sitting with the 503 bios that came with my board, haven't even tried 603 - everything is working perfect (running even Samsung HDDs in RAID, which are supposed to error with these mobos), so there was no need for me...
Whats the best BIOS for this board with a Q6600, friend of mine just got this board
100 % would say 0602 or 0603 either bios is fine..
some people prefer 0603 some 0602
bios 0603 doesnt DEACTIVATE the wifi card, might be the reason why Asus doesnt have available
should it deactivate the wifi?
That choice is up to you to make.
I'm getting an E8500 on Monday probably. Will leave my current 0603 on and see how it goes with it. If i can't get it to start and have to go borrow some Conroe to update then i'm gonna kill somebody.
Didn't anyone try a wolfie with the 06x bios?
For day to day yeah but going for max clocks i bet i'll use more then 1.6.
Can you upgrade the N/B-voltage regulator heatsink so both sets of voltage regulators are covered?
I am very confused, shocked and happy atm. Hopefully someone can tell me what is going on.
I am running 0906 BIOS, have been having the vdrop issue like everyone else.
Whilst testing a 24/7 OC at 4.2Ghz, I noticed that vdrop was only 0.03V or so, now I set the voltage to 1.7V and am getting ~1.66V, still on 0906 AND THE VDROP IS GONE???? :shrug: :shrug: :shrug: :shrug: :shrug:
Screenshot.
http://i138.photobucket.com/albums/q...rydg/1656V.jpg
That's some weird ass stuff man :shrug: Hope mine stays like that after i update :D
The vdrop now seems to be coming and going, I ran some quick tests with the higher voltage but it doesnt help my CPU much, maybe even makes it a little worse in SPI 1M, helps a little in 3DMark06.
With the times it has or hasn't worked, There has been one thing in common, if I set the voltage <1.6V, but <1.7V(1.6 or 1.7 exact had vdrop), it didn't have the vdrop.
What happens to everyone else when you set 1.6xxV?
Does This cooler fit on the upper Mosfet.
http://images.google.be/imgres?imgur...%3Dnl%26sa%3DN
Yeah. Only one of them fits though (U or S). Check thermalright's site as they have info for which fits on that spot, on your motherboard.
No need for an X38. The P5K-E is a champion :)
