Originally Posted by
JohannesRS
I mean, if icc gives an increase performance from "do not use SSE extensions" to "use SSE extensions" of, lets say, 15% on an intel cpu and of just 10% on an AMD cpu, then that would mean that you are right. But when the same code, compiled with MS compiler, sun compiler, portland group compiler or even gcc shows that turning on the SSE on both architectures yelds similar increasements (say, 15% and 14%), then you have to begin to consider that, yes, intel compiler is giving problem for AMD machines, consciously. ;)
