Wohooo! :D
Just got my nozzles from Overclock-UK! Just simple mail and only few days from UK to Germany!
Well, let us see, what it brings to my Q6600. ;)
Maybe nothing, maybe some drop. (drop in flow for sure haha)
Wohooo! :D
lol @ sig :shrug:
It is a wise sentence at all :yepp:
Originally from Bruce Lee! :p:
I like it very much! Especially the words, that it can flow or crash. :cool:
My tubing wasnīt secure for 2 times (while testing the loop) and the water splashed through my case. I was very busy cleaning it all. If this happens to my computer while running, it crashes. If the tubes are secured, it flows.(~450l/h) :D
I thought you were going to say it was from a fortune cookie :)
my nozzles are pretty good and so is my new q6600 has a low vid and overclocks like a charm i got 3.2ghz @ 1.35 havent really banged out because i just got my p35-dq6 but voltages are very stable vdroop isnt that bad and temps are all around 33c except 4th core its around 28c
bruce lee is my hero!!! :)
:up: nice one! :D We should give this idea to a fortune cookie maker! :rofl:
Mine too! Since I heard about his words regarding water and this german joke: http://www.myvideo.de/watch/103085
I donīt know, if you could understand anything, it is german, but if, it is very very funny :D :D :D
Back to topic:
Did you test it with nozzle only on your CPU? :rofl: How did you fit the nozzle in your loop?
Just kidding The D-Tek itself is a good cooler. The question is: Is the D-Tek better with nozzles or is it as good as without. ;)
The temps in idle are not that interesting. Full load by stress tools like prime95. ;)
D-Tek without Nozzle!
1,45Vcore = 3,6 GHz Temps on load around 59-62C°
1,48Vcore = 3,7 GHz Temps on load around 65-67C°
Just installed my nozzles and had a nice temp drop of between 3-5c!
Much more than I was expecting and the tim has not had time to setin yet!
Can you guys post what nozzle you are using, since there are a bunch. :)
4.5mm for core2duo.
Well ive been using the 4.4mm, I just got a Q6600 today too (G0) and i will keep the same nozzle in.
4.4mm??? Must be making fun of me.
When I first go my nozzles I measured all them and I swore they were .2mm off each. Upon further investigation, they were the advertised sizes. I was so paranoid about it I actually took an awl and burnished the 4.5mm nozzle opening to 4.7mm (since that's what I was told is the optimum opening size)
I do wonder what will work best for the Quads, but there is no question with dual cores.
Did quad nozzle and temp is the same. :(
Im using the smallest nozzle.
CPU is 6400 @ 3400 @ v1.45
Temps before 40/42 @ prime load
Temp now 35/39 @ prime load
Fans are fn121 @ 7v
But I have dual d5s (on setting 3 and a pa120.3 and pa120.2) all for CPU :)
fyi air con is set at 21C however ambient is about 20/19C
Overkill :D
Only one PA120.2 should do the same work in cooling the CPU.
Quadnozzle and washer mounted.
Temperature dropped 2-3°C.
Flow dropped from ~425l/h to ~350l/h
If it really comes from the nozzle, it is a good thing for enthusiasts. If not, it was a better mounting of the cooler on the cpu now :D
using the washer and the nozzle are the only steps needed to get the block bowed? Any other procedure?
