Try it ?
:p:
Got my 4x1GB Crucial Ballistix PC8500 up and running now.
So far 440FSB ratio 3:4 = 586Mhz (1172Mhz DDR) @ 2.06v
Cant do higher FSB with this crappy CPU. Getting a Xeon 3220 tomorrow and hopefully it will go past 450fsb without any problems.
http://img136.imageshack.us/img136/5...istixv1wj8.jpg
Yup, Crucial Ballistix Tracer 8500 Memtest stable at this (PL7): http://img225.imageshack.us/img225/3066/675yb2.png
2.35V, Delta 220 CFM on them just in case. ;)
Easily. Did that at 2.0V for me.
1Τ Set Fron Bios Dunno Why Cpu-z shows 2t :( or my abit is crazy or me :p
@2,3Volt
http://img135.imageshack.us/img135/2879/85401447gq0.jpg
Awesome performance from this kit.
Is it the best price/performance enthusiast kit out here?
Vatos Im almost sure you wont be able to run 1T at those speeds.
Stick with 2T :up:
1t is not possible on Intel chipsets, only on nVidia 650/680 chipset.
Lord AnthraX 1T is posible @ 600Mhz
Zeus i realy don't now :) i just set it this way on the Bios and the board boots so i don't know :) is there any way to check for sure if the run at 1 T or 2 T ?
:D your wellcome :up:
http://img152.imageshack.us/img152/25/30166710mp6.jpg
My P5K-E wifi refuses to boot at 1t, even at DDR800.
Rather strange yours seems to boot, so if it does, i don't think it's running 1t actually but just 2t like CPU-Z says.
i don't know memset sais 1T Cpu z sais 2T everest does not sais CR so i don't know witch software sould i trust i can see tho tha both cpu z and memset have some isues with Abit Ip 35 Pro
EVEREST Ultimate v4.20 1180 or 1183 will report CR (Command Rate) under the Overclock menu. ;)
Mine does not boot with 400FSB 1:1 4-4-4 timings at 1t.
Not at all. :shrug:
It's also P35 chipset.
Zeus what if you throw it to 4-5-5 timings @1T instead and higher tRFC?
I just got my Ballistix 8500's and I need 2.17v to do 1060 5-5-5-12 on the 4:5 ratio. Seems I got a crap P35-T2R as I cannot run 4GB stable and all my kits od D9 clock like ass on this board and all of them need high Vdimm :shrug:
