OOOPs, I never looked in there after I hit Ctrl+F1.
it's in the Intel chipset design to set straps and co if you alter settings or cold start, I had the same as with the P5W (975), P5B and now P5K Dlx...
Guys...is 2.35V on the memory safe?, i don't have active cooling. My memory is now set to 1134Mhz (1066 standard 2.2V). I've done some testing and it seems stable, but voltage/heat concerns me.
Has anyone got the Corsair PC2-8500C5D kit to 1200MHz?
yes n no lol i runnin @ 2.35
my mushkin is covered on 2.35 but they recommend active cooling
not worth the hassle of rma
i got 2 80mm fans on them
the rbsmontemor mod is best i think my ram is cool to the touch
http://www.xtremesystems.org/forums/...d.php?t=148783
2.35v is too high for passive cooling in my opinion. some even would say 2.35v won't bring guaranteed results for more than a year even if active cooled.
My friend ran some gmh at 2.32v actual for about 2.5 months without active cooling (although I'd imagine his aircooler should have at least brought a slight draft of air by the area) and it started having posting issues at 1.8v, requiring "jumper sticks" to get to use them after a failed overclock. By 3 months, one of the sticks died. He went single stick as he waited for new sticks, and a day before the new sticks came in, the single stick died.
Realtek sound problems. I installed the Realtek drivers from the Gigabyte CD-ROM, and when I play the 3D Audio Demo on a pair of bud ear phones, the L and R are reversed. If I use a larger set of headphones, the L and R are correct. I tried this with 2 pairs of large and 2 pairs of bud size headphones and both bud size headphones are REVERSED.
I just installed v1.7 driver from Realtek and the problem persists.
Anyone know how to fix this?
Anyone else find the onboard sound on the P35-xS3x a little bass-less?
I gave up on it and chucked an Audigy into my PC - I haven't heard such lack-lustre onboard since my S754 MSI K8N Neo-FSR (and I'm pretty sure that was just due to a fault) :rolleyes:
[EDIT] Yeah so I had another go with the onboard and it's because I selected HEADPHONES in the driver panel that my sound output was terrible, so stick to the "Line Out" setting
Hey is the GA-P35-DS4 a good board for overclocking the Q6600? The P5K is about the same price.
i think this board is quite good
my result with DS3 and ADATA ram
http://valid.x86-secret.com/show_oc?id=213825
what the different beetween DS4 and DS3 instead the 2 PCIe slots and some heatpipe?
New P35C-DS3R review:
http://techgage.com/article/gigabyte_ga-p35c-ds3r/
wuhuu my qx6700 manage to hit 3.91 on air with this p35t dq6 :D
Has anyone had trouble when the monitor goes into sleep mode, then wakes up and displays nothing and flashes the green power light? I know the OS is running and not crashed.
I have trouble even getting a display on post. I have to reset the bios and hope for the best. Sometimes it gives a blank screen and flash power light halfway to loading windows. I cant use monitor power saving only screensaver.
I think its the mobo. Although it in theory could be the graphics card or the monitor too.
Its the only issue I had (apart from e2160 having lw fsb wall of 395fsb), but its quite a show stopper.
Reminds me of my dfi infinity nf2 pos, but at least my board holds an overclock.
OK! I wonder wilkl I have issues just dropping my Xp install from DS3 3.3 into a P35 DS3 board. I reckon I might be ok after I install P35 drivers first and then do the swap? I remember when the S3/DS3 came out first it was nearly impossible for people to slipstream drivers etc ... everyone needed a fresh XP install.
Which board is better for overclocking with QX6700 and xtreme cooling.
P35-DS3P, P35-DS2R or P35-DQ6 ?
New bios releases available; P35C-DS3R, F4b beta:
http://www.station-drivers.com/telec...c-ds3r_F4B.exe
P35-DS3, F4:
http://www.station-drivers.com/telec...p35-ds3_F4.exe
P35-DS3R, F5b beta:
http://www.station-drivers.com/telec...5-ds3r_F5B.exe
P35-DS3P, F5d beta:
http://www.station-drivers.com/telec...5-DS3P_F5D.exe
P35-DQ6, F5h beta:
http://www.station-drivers.com/telec...35-dq6_F5H.exe
P35T-DQ6, F3c beta:
http://www.station-drivers.com/telec...5t-dq6_f3c.exe
So anyone tried the F5h beta for DQ6 yet? any difference to F4 bios?
Any one has a change log for those new beta bioses ? :D
