Thanks :)Quote:
Originally Posted by e-jump
Thanks :)Quote:
@ Sideeffect, do you know on what bios this HyPeR-XT Bios Ver. 1.1 is based ? the new 1.c0 ?
and on the msi ftp, i saw Bios 1.D1 someone tried that one ?
1.D already?
jeebus.. msi's bios department need to fix lotsa isues n release a good fixed bios, rather than releasing 1 bios for each fixes >__>
I Have big problem with my Mushkin 2x512DDR 550MHz ram (probably TCCD chips). I fried about 8 BIOSes (all these BIOSes are unstable on ma computer. Problem is in Memtest!!!
I am testing on 312HTT(FSB), HT 3x, divider 183=560MHz 2,5-4-4-8 T1,
2,75-2,85V
T tried MODDED Balistix and TCCD BIOSes...
What can I do for stability?
Are you sure your cpu can handle so high mem speed mine can only make it to
510 but my mem can do 530
xxbiker
Ok I modded 1.D Beta 1.
works fine so far on my rig not sure what has changed. Msi changelog = changed name from 1.C to 1.D beta 1 :p:
So let me know how it goes for any of you that can be bothered to test it. No options have been added so it must be some other tweaks perhaps new cpu identification or tweaked vcore etc.
i'll try, if it comes with ultra loose tref, mal n rp :D
Yes sry e-jump ive been lazy so I stuck with the already compiled settings eg. TCCD/ballistix. If I change the settings I have to compile another version which doesnt take to long. Ill do it this weekend and once its done its easy to add to any future bios as well.
How is every getting this board to run memory up too 250mhz (500) mine won't go past 211mhz, I have corsair pc4000 pro, ran memtest with no errors,
my cpu is operation 148, setting are 250fsb, ht at 4, multiplier set to 11 memory at 183mhz that is the highest I can go. mem setting are 2.85v, timmings are 8,3,3,3 430 true power supple, HELP PLEASE, also using sideefects bios 1c.
thks
coop
@coop
so u have opteron148 with 11x multi, but u cant run ur rams to ddr500?
is the ram rated ddr500 3-3-3-8?
tried reducing the HT to 3x?
how bout try multi 10x and see if the ram can go ddr500
im having random reboots with 1.c final, so im back with 1.c beta3 bios
are u using 183:200 devider? seems opty users have this prob
try 200:200 instead
have updated my BIOS to your 1.C TCCD ed. and have noticed a big improvement, BUT my system is still unstall @250. ( just blue screens in games normally. and fails tests. BUT NOT mem86 ! )Quote:
Originally Posted by sideeffect
I'll try 1.D over the weekend, and see what i notice. but don't think i'm quilified to be your No.1 tester ! !
Yep my memory is rated ddr500 with 3,3,3,8. i'll try the 10 in the morning when I get home, haven't tryed that yet. did try the ht @ 3 that didn't work.Quote:
thankyou for the idea, I'll post back what I find out.
coop
how high is your memory voltage?
lol :)Quote:
Originally Posted by cooptroop4
2.85 volts, thats is the highest it would go, stock is 2.75
thks
coop
SideEffect, Do you always use the same method to implement the 183 and 150 dividers? Is there maybe only one method? Do you know of anyone that cant use "your" 183 div, but can use 183 with some other modded bioses ?
cooptroop4, have you tried to clock to 250MHz with 2.75volts ? Maybe your ram doesn't like this high current.
One thing i've noticed on my K8N.
The VCC starts to fluctate pretty heavily when i dual-prime for some time. With 1.C3 SE mod the Vcore became very unstable when the VCC started fluctating.
1.C SE mod Final cured the vcore fluctations alot. I also put heatsinks on all the vcore voltage regulators, and on most of the capacitators near the cpu. VCC became much more stable, but still it sometimes falls like 0.1v, sometimes even more.
I will post screenies both before "1.C and heatsinks" and after when i'm @ home :)
Just tryed it @ 2.75v, ht set too 3, and multi. set too 10, did it different ways, wasn't stable at all, windows would only run for about 1min than it would reboot, also I'm using a sata drive if that helps, its in the 3 slot.
thks
coop
cooptroop4 - dont use the 183 divider, lots of people say they have trouble with it
Hi guys
MSI Fixes in 1.D1 = Added FX60 support :toast:
Think thats all they did.
The 183 and 150 dividers are locked by MSI and so I doupt MSI test them when they test their bioses. Because of that they may have issues with certain cpus ram etc. It wont damage the board or anything but just might prove unstable for some.
However its better to have the option so we can all see for ourselves. On my san diego cpu the 183 works just fine.
I'm on 1.d now, but it hasn't fixed my divider problem.
However, I sunk so low as to try the 1:2 divider.. Currently at 305x9... lol
Looks like I might have to get a new board? :/
Really wish I could use that 133 or 166 divider...
edit: crashed at 310x9
I'm thinking now...
Crashes at ~310 on the 100/200
Crashes at ~280 on the 133/200
Crashes at ~245 on the 166/200
Testing 150/200 now..
And by crash I mean the computer hangs instantly. :(
the 183 divider gets me the hightest stable speed I can get for the memory.
thks
coop
sideeffect can you do the no temps edition for tccd?? i have a lots of problems with my opty 165 with the tccd memory...
thkx :D
K would love to see what you did and R waiting in anticip...ation for these screenshots =DQuote:
Originally Posted by Gnarr
K has never been able to make 2GB of RAM 1T stable @ 250MHz on this mobo =[Quote:
Originally Posted by blade148
*new subject*
Just installed a RAID0 array for the first time, and am pleasantly suprised with the extra boost in speed (BF2 loads SOOOOOOO fast now), BUT, when trying to read the old SATA HDD on port SATA3, it seems to lock up the system =/
Is this normal, or did the new HDD's arrive just in time to replace what was a suspected dieing HDD?
I would also like to see those screenies Gnarr :toast:
oh noes...
se's bios page is downs again..
btw, juz got my ram coolers today..
manage to push the rams to ddr520.. but still cant make it prime stable..
superPi 16M failed the last iteration .. means need more tweakin..
any news of uccc edition? :p
