Originally Posted by OneyedK
Annoying? Like, someone posting the same question abou three times? ;)
Problem with sleep mode is, that the before going into sleep mode,
the current state of the PC is copied into RAM.
As long as you RAM is at stockspeed and spd (voltage and timings), the pc should be able to recover. (unless the nb and cpu power come up too slow)
If the RAM is overclocked in any way, you suffer data loss when the pc goes into hiberantion, so the data to reinitialize the pc is lost, thus you cannot revive the damn thing without a restart.
The reinitialisation requires some bios actions, wich will fail. So after a reboot, that flag is still set and will result in the "overclocking failed" message. You just have to enter the bios, do nothing and boot again...
So no, I don't use sleep mode, I just switch off my screen and external harddrives...
And, btw, this has NOTHING to do with P5W DH problems...
