Is vdroop only between idle and load? The thing with my board is that if I set 1.375v, it's only 1.328v at idle and 1.312v at load. The droop between idle and load isn't bad but the actual setting is way higher than either. I'm guessing this isn't droop right? You may say that this isn't a real problem, but I've found that 1.6v is unstable and isn't actually 1.6v at all, so my limit is whatever the highest 1.5v is and that is actually around 1.50v idle 1.49v max.
