Jor3lBR, was that done on the cryo?
:up:
@Jor3lBR
Very nice work :up: :clap:, some awesome chip you got :yepp:, keep the good work up.[/QUOTE]
Thank you. Any BIOS will do, I used F8 and F4.
I updated the thread with cooling used. CPU: 1 x MCR220 + 1 x Thermalright XWB1 + MCP655 + 2 x NMB-MAT's
Cryo-Z is only for benching now otherwise the electric bill would be to the roof.
Thanks for posting your settings Jor3lBr. :up: I think my q9650 is capable of doing 4.5ghz using those settings + a little bump vcore but temps are out of control. Guess I need water cooling for a stable 4.5ghz. Not sure I want to spend any more money for a 775 rig with the i7 prices dropping though.
Watercooling is knocking on my door too OC Nub :welcome:
Just not sure what to order or how much of a pita it will be to change out hardware. Is it possible to get a real good setup for $300 or less? I hit 85c+ in LinX at 1.3875v. My CPU needs that or a little more maybe to reach 4.5ghz. Will water cooling get my temps low enough to run LinX?
I've been looking at the Swiftech H20-220 Apex Ultima watercooling kit that Leeghoofd has in his sig and did a review on.
I saw that also but have heard that kits are not the way to go.
I know that's the default statement. But this has a top notch CPU block, pump, and a very good radiator. For just CPU cooling this is more than I would need to run and 45nm Dual or Quad core. Ans at ~$225-250, the price is pretty reasonable compared to a custom setup. Not all kits are bad kits and some are very very good.
http://www.madshrimps.be/?action=get...70&articID=897
Im all for a kit, for one it would save time picking out parts and paying for multiple shipping charges. I just wonder what kind of results I will see. 5 to 7c lower doesnt put me where I need to be. Maybe Im not going to find what I need using water IDK. :shrug: Maybe xtreme cooling is what I need but IDK if there are any that can be run for extended periods of time. I mostly play games and just fool around with oc'ing in between gaming.
Hey guys this is what I have. Been priming for 8 hours now. Ran the intel burn test 15 times no problem. The DDR3 ver of this mobo sucks for clocking ram. Good luck getting it over 1600MHZ unless your using the bugged 3:5. Anyone got getter ram speeds? have you seen that it seems like you have to run a little more then the rated voltage to the ram?
http://i116.photobucket.com/albums/o...ghank/4250.jpg
Tell me about it, I have almost the same problem, I get past 1650 with 2x2 Transcend 1800C8 but then it starts to get me problem and the same with 2x2 Crucial Value 1333C9 (D9KPT), I donīt even get my 2x1 Dominator 1800C7 to run at rated speed. :mad:
I have seen one that have achive 2x2 DDR3-2000MHz @ 1,92 (Crucial Value 1333C9 :eek:) on this EP45T but it was with a dual, it was pangingIII, check this out, donīt know how he did it but he did.
Leeghoofd had the same problem, a think that he had a little better luck with those low volt Elpida Hyper.
The good thing is that run a 45nm quad ~FSB 500 with these UD3 board is so easy. :up:, I just love it.
But FSB 500 ram DDR3-1600C7 is a little better then FSB 500 ram DDR2-1200C5 though, hope that cheer you up a little. :)
right on thanks! Looks like F1 bios could have something to do with it. man thats some fast ram!
been gone for a couple of weeks(no internet) but i got to say there are some great results
that have been posted while i was away.
P.S. great to see Jor3lBR back in action in the thread,went quiet for awhile.
Hey,
I can't seem to be able to go 1200Mhz+ DDR2 on my OCZ PC2 9200 Reapers. I used to be able to hit 1206Mhz Pl8 no problem 12 hours Prime blend stable when I tested with 8800 Ultra as primary gpu but now with HD 4870x2 as soon as ram hits 1200Mhz or higher (2.50A multiplier strap) Prime blend throws errors within an hour.
Running F5 bios, do I just need to tweak the Cpu VTT, Mch core/Mch ref values more?
hello guys...
i have a problem with my new platform...
can i say what is max pll voltage on my gigabyte ud3p?
my cpu is an q9650@4300 vcore 1.375 100% stable on asus maximus formula
i don't know max voltage for daily use and because now prime 95 give me an error on one of 4 cores...:confused:
this is my actual settings from bios and easy tune :shocked:
http://www.pctunerup.com/up/results/...2_Immagine.jpg
thanks in advance
magnifico :cool:
@hank123
I see that you still hanging on to that EP45T even though you donīt love it.
i have just upgraded to 8gb of memory i have 2x TW2X4G6400C4PRO 2x2gb
and i have had the rig at 3.5ghz overclock with only 2 sticks of 2gb but getting the cpu @3.5 means the memory goes to 876mhz.
But i dont know if its safe to overclock memory and how long it will last at 876mhz i have 4sticks of 2gb now can anyone help me becuse i cant get the memory any lower in speed.
The motherbord im using is the ep45-ud3r i have a gtx 280 no oc and all i want to know is i have the cpu @3.2 and it is stable is it worth going for 3.5 and overclockg the memory as well im curently getting 16553 on 3d mark 06 if it helps
thanks guys i hope you can help
ya dude I have a Rampage Formula coming in. kind of sucks that its only ddr2 but it will be fun to play with.
The FSB is sweet on this mobo. right now got the e8500 running at 4.5 with 1.360V under load. had to bump the voltage a little failed prime95 after 13 hours 1 min
Can someone please guide me to a good starting template for a Q9650 & UD3P running at 4050? Just upgraded to this board today.
System info:
Q9650 Batch # L836B361 w/ VID of 1.2250
Gigabyte EP45-UD3P
G.Skill 2x2GB Pi Black DDR2 800 F2-6400CL4D-4GBPI-B
Core-Contact Freezer
Antec P180
Corsair 520HX
this
http://www.clunk.org.uk/forums/revie...-review-2.html
and this will help some.
http://www.ocforums.com/showthread.php?t=515316
Biggest thing is figuring out the % stuff. You gott know how to do math. Its gonna take some reading. the more you read the more you learn. the more you learn and really understand the HIGHER your OC will be. I have spent 30+ hours getting to know this board. Ya i still think the DDR3 ver sucks over the DDR2 ver but its still a great mobo for the price.
