Originally Posted by
DaLiu
Guys i have a question, i tried to find all over the internet any detail about the NB and SB temps and how they can be fixed, i think the biggest problem is the "legs" (dont know how to call them) from the heatsink (SB-NB-heatpipes), they are a little bit long and even if i use washers under the mobo basically i cant make the heatsink to put pressure on the NB only if i cut a little from the legs, i hope you understand me, and im sure this is the biggest problem in my case because i already desamble the heatsink from them mobo 2 times just to be sure that i put the MX2 correctly on NB and SB. I tried to find a better picture with the heatsink of M2F but i didnt find any from different view, basically there are the legs with some hard rubber over them, i think if i manage to take off that rubber i could put a better presure over the nb, sb and mosfets (even this are going on 60C in full load). What do you think, right now im waiting for Prolimatech Megahalems which is coming only in 10 days and when i have the cooler im going to try to fix the heatsink as i said.
