That is a real nice idea, Dunno how you guys call it over there, but its for heat dissipation isn't it?
How are the results?
Behave!
It's for bling :)
Seriously who like that pcb green? Hmm I need some black acrylic
Conductivity :p:
but it won't touch it metal to metal. i have used doublesided 3M tape to put it on those screws
Hey, it's overrated. :p:
A layer of acrylic underneath it (or something) would solve the problem. I'm a bit scared about just using tape after I fried a card by dropping an LED light on it which I thought had a plastic casing. Turned out it was some cheap metal.
back agaín
I got my HD4870 a few days ago.
http://i292.photobucket.com/albums/m...iew/PicOne.jpg
http://i292.photobucket.com/albums/m...iew/PicTwo.jpg
http://i292.photobucket.com/albums/m...w/PicThree.jpg
http://i292.photobucket.com/albums/m...ew/PicFour.jpg
http://i292.photobucket.com/albums/m...1111111111.jpg
http://i292.photobucket.com/albums/m...yComputer5.jpg
I also got 2 more Scythe Ultra Kaze 3000rpm fans, I added one onto my IFX-14 and the other is blowing on my RAM :D
Hey how is that cooler on your Gainward 4870?
Hey fatguy1992, looks sweet.
How loud is your PC with those 3 Kaze's? I'm running 1 and it sounds like a jet engine...
I'm assuming you have the 3,000s, right?
how's that xigmatek fan? i like and i was thinking of ordering some, but i dont know if they perform well. Nice rig BTW
I have a coolit ram cooler and it works GREAT, when i touched my tracers when it wasnt installed i burnt myself, now they are a lot cooler. Looks a lot better than the OCZ one to me, i modded it with red leds :)
http://img65.imageshack.us/img65/1488/img6978br0.jpg
http://img162.imageshack.us/img162/2141/img6980dt5.jpg
http://img234.imageshack.us/img234/7260/img7012kc1.jpg
http://img440.imageshack.us/img440/1624/img7015fp1.jpg
http://img206.imageshack.us/img206/9753/img7013an5.jpg
sorry for the bad cabling, i have too many fans (12) and not enough time!
OdinEidolon, are those Xilence fans any good? I was looking those to my HTPC cuz those are so cheap and looks good..
thx, thats good to know.. maybe i just buy few scythe s-flex fan..
Works well. It was the fan that came with the xigamtek cooler and just decided to put a stronger fan on it instead so moved the xigmatek as exhaust. It pushes a ton of air and is quiet, but that could be due to the stronger fan on the heatsink pushing more air.
