Not happy with my system!!
Dear all,
I appreciate if somebody answers my crazy question:
I have a 3200+ venice processor installed on msi k8n neo2 plat. Whatever I did up to now, I could not boot the system up over 270mhz fsb with 10x multiplier (Vcore increase does not help either). I have tried almost everything such as switching between various bios versions (official and modded ones) and all sets of combinations regarding cell menu settings,HTTx, ram timings etc.
I've even switched my processor with another 3200+ venice, but the results are almost similar. Is there any known bug limiting Neo2 Plat. to run over a certain frequency/speed or is this typical for all nf3 based motherboards? When I lower the cpu multiplier, it lets me to set higher fsb naturally, but anyway I hit a wall around 2700mhz. And this 2700 ghz is to boot up only, the system is totally unstable at that speed that prime95 reports error in first 20 seconds.
I'm not an extreme oc expert but I 've sufficient knowledge concerning how to alter/set critical parameters in Bios. I don't also think it is a Ram issue. I browse through various forums and hear that people reaches crazy values of 300,320,330 and even 350mhz fsb with 3000+, 3200+ processors. (For sure u need good cooling to reach 300+) The thing is my cpu does not exceed 41degreesC(bios reading) even if I push the Vcore around 1,75v by using bios 1.36b.
Configuration:
K8N Neo2 Platinum
amd 3200+ venice ADA3200DAA4BP E3 Stepping lbble0537
psu: ocz powerstream 600adjsli
ram: 2x512 Gskill Extreme F1-4800DSU2-1GBFF (ddr600)
ocz ddrbooster
cooling:Zalman CNPS9500 air cooling
sapphire radeon 9800pro@9800xt bios modded
Platform: winxp pro sp2
Is this a cpu problem or mobo or nature of nf3? Windows oriented issue maybe? Any ideas?
Thanks in advance..
