This is a vdroop you mention above but i am talking about idle values.
http://support.asus.com/faq/faq.aspx...Language=en-us
Vdroop - when volt is HIGHER than what it should be? I assumed vdroop was that it was lower than set.
If we consider that all the hardware on the system works fine then,from what i know at defaults this mobo adds 0.005v for the NOS and AI Booster futures to be able to reach the 10% overclock.
If i enable OverVoltage CPU VCore in BIOS then the system adds 0.2V which is too much voltage,at least this is what happen on my mobo.
Also this is what i have read in all forums for the A8N32-SLI deluxe mobo.
stealth
