Sergio, just stick to 185.85 for the meantime.:)
With my new OCZ Platinum pc2 9200 1.8v ram i cannot get into windows at 1150 with pl8 L M A O. Been a bad week for me and hardware. Time for a new platform.
My G.Skill 9600 PI 2x2GB 1200Mhz kit just arrived! :up::up::up:
Damn, these babies run hella cool even at 2.1v. http://valid.canardpc.com/show_oc.php?id=585259
Is it possible that the CPU doesn't like a divider and does best at 1:1/200d? I have only run this e8400 using 200d pl9 due to not having a 4gb kit that would go much past 1130. On other boards I have had CPU's that would clock well at 1:1 only and some that seemed to like a divider. I know the chip is good up to 495x9 prime stable 8hrs. Maybe I am wrong about this idk.
Cpuz hw monitor and Everest shows 1.79v when set to 1.82v in bios, maybe needs another bump. Went as high as 1.40v mch but that is to high for 1150.
I also put this ram in my other rig with a q9550 and could not get it to boot into windows at 482x8.5 all the way up to 1.35vcore 1.40v mch, I have run this chip at 500x8.5 1.35v bios 240b prime stable but using a 2x1gb kit of d9's.
Oh yeah, those clocks are damn hard to crack and WC helps a lot to keep it cool.
Looking good :up:
You have all rights to be proud of your gear and sometimes one have to show off when one have succeed to put some good gear together as you have, no offence taken, you got my respect. :yepp:
I have a hard time to get my 2x2 ram stable above DDR3-1640 (~FSB 515) with CAS7 tRD9, probably I have to lose the timing to CAS8 and tRD up to 11, doesnīt look good but I have to see what kind of score I get and if itīs worth sacrifice bandwidth and latency and gain CPU clock speed.
Keep up the good work Sergio :up:
Looks like Iīm starting to closing in on that wall, it getting harder to get it stable through Vantage in Win 7, hade to rise to CAS 8 @ 1648 with tRD10.
Iīm trying to get above 15k in Vantage without PhysX but itīs a struggle.
This is my latest run.
http://i282.photobucket.com/albums/k...TtRD10Turb.jpg
This board has issues with 2.40b at certain fsb and mch voltages. Post a template of the settings your trying or wanting to use. Mine will not boot 479fsb with 2.40B(1150) with any mch voltage higher than 1.32, go a little higher fsb and it has no problem booting with more mch voltage. As I said this board is picky with the 2.40b and it each of my ram has reacted differently with that strap.
Thanks HOSS, This is on my q9550, I know the CPU is good for it, trying to get the mem to do 1150 or higher. I am in windows now at these settings minus ram settings, currently at 200d pl9 1.30v mch. Have tried raising the VTT also but never needed any more than this, think its a ram, mch, or maybe my refs that need work. Or the Ram just wont do any higher.
******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 ]
Fine CPU Clock Ratio............................[ + 0.5 ]
CPU Frequency 4.15GHz...........................[ 489 x 8.5]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 489 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2.........................................[ Disabled ]
******Advanced Clock Control******
CPU Clock Drive.................................[ 800mv ]
PCI Express Clock Drive.........................[ 900mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
(G) MCH Frequency Latch.........................[ 333 ]
System Memory Multipler.........................[ 2.40b ]
Memory Frequency 1150...........................[ 1178? ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 18 ]
******Advanced Timing Control******
tRRD[3].........................................[ auto ]
tWTR[3].........................................[ auto ]
tWR[6]..........................................[ auto ]
tRFC[54]........................................[ auto ]
tRTP[3].........................................[ auto ]
Command Rate (cmd)[0]...........................[ auto ]
******Channel A Timing Settings******
Static tRead Value [ 8 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 8 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ oc1200 ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.2125 ]...................[ 1.350 ]
CPU Termination [ 1.20 ]...................[ 1.260 ]
CPU PLL [ 1.50 ]...................[ 1.450 ]
CPU Reference [ 0.760 ]...................[ 0.823 ]
MCH Core [ 1.100 ]...................[ 1.30 up to 1.4 and a no go ]
MCH Reference [ 0.760 ]...................[ 0.838 ]
MCH/DRAM Refernce [ 0.900 ]...................[ 0.900 ]
ICH I/O [ 1.500 ]...................[ 1.500 ]
ICH Core [ 1.100 ]...................[ 1.100 ]
DRAM Voltage [ 1.800 ]...................[ 1.840 ]
DRAM Termination [ 0.900 ]...................[ 0.900 ]
Channel A Ref [ 0.900 ]...................[ 0.900 ]
Channel B Ref [ 0.900 ]...................[ 0.900 ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disab
What other FSB have you tried? Try this, lower your fsb to around 463 and change over to 2.50A, if this boots your problem is probably the board/2.40B.
I started at 479fsb to try and get the ram to 1150 but couldnt get in windows, then tried to go higher, up to 489- 4.15ghz to see if it was a fsb hole like you were saying but haven't been able to get it to boot into windows with the 240b. Will try that now Thanks
Nope, cant get into windows, have tried on 2 different UD3P's tonight with same results. I was able to use 240b 1200mhz pl8 with a 32bit OS using 2x1gb of Dominators 1066. Maybe it just wont do it with a 4gb kit:shrug:.
Thanks for your effort.:up:
EDIT: If I change the clock skew to 1000/1000/0/50 I can get into windows with 240b:confused:.
I didnt try the 200d that I remember before on this chip. Gave up after500x8.5 because my mem wouldn't go any higher and I needed the clock skew at 1000/1000/0/50, didnt want to use that. So maybe I can get back to OC'ing now for higher fsb with the 200d.
Still a work in progress.
[IMG]http://img231.imageshack.us/img231/2671/32m959566.jpg[/IMG]
First of all, if I have your memory identified correctly, it's rated voltage is 2.2V. 1.84 is quite low. The default voltage of 1.8V is always that, as it shows the default voltage for DDR2 in general. I also think your static tRead value is too low for this FSB. try 11 or more, at least until you are stable.
MCH Frequency Latch - Set to 400 with a multiplier of 2.0, or auto with a multi of 2.0D
Other suggestions as well.
I have 510x8 stable (Tested many things over a week), my next step is 520FSB. So far my attempts have been pretty poor so would welcome any advice from the seasoned Pro's that frequent this thread :clap:
I am trying to fnd the maximum speed I can run the FSB at so if I have to use x7.5 that is fine.
510x8 Template...
Code:*************************************
Gigabyte GA-EP45-UD3P (Rev. 1.0) - F9
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..............: [Auto]
CPU Clock Ratio ......................: [8X]
x Fine CPU Clock Ratio................: +0.0
CPU Frequency ........................: 4.08GHz( 510x8.0)
********** Clock Chip Control ********
>>>>> Standard Clock Control
CPU Host Clock Control................: [Enabled]
x CPU Host Frequency(Mhz).............: [ 510]
PCI Express Frequency(Mhz)............: [100]
C.I.A.2...............................: [Disabled]
>>>>> Advanced Clock Control..........: [Press Enter]
CPU Clock Drive.......................: [800mV]
PCI Express Clock Drive...............: [900mV]
CPU Clock Skew........................: [ 0ps]
MCH Clock Skew........................: [ 0ps]
******** DRAM Performance Control ********
Performance Enhance...................: [Standard]
Extreme Memory Profile(X.M.P.)........: [Disabled]
(G)MCH Frequency Latch................: [Auto]
System Memory Multiplier (SPD)........: [2.00D]
Memory Frequency(Mhz).....800.........: 1020
DRAM Timing Selectable (SPD)..........: [Manual]
>>>>> Standard Timing Control
x CAS Latency Time................5...: [5]
x tRCD ...........................5...: [ 5]
x tRP.............................5...: [ 5]
x tRAS...........................18...: [ 15]
>>>>> Advanced Timing Control.........: [Press Enter]
x tRRD............................3...: Auto
x tWTR............................3...: Auto
x tWR.............................6...: Auto
x tRFC...........................52...: Auto
x tRTP............................3...: Auto
x Command Rate (CMD) .............0...: Auto
>>>>> Channel A Timing Settings.......: [Press Enter]
x Static tRead Value..............7...: [ 9]
x tRD Phase0 Adjustment...........0...: Auto
x tRD Phase1 Adjustment...........0...: Auto
x tRD Phase2 Adjustment ..........0...: Auto
x tRD Phase3 Adjustment...........0...: Auto
x Trd2rd(Different Rank)..........6...: Auto
x Twr2wr(Different Rank)..........6...: Auto
x Twr2rd(Different Rank)..........5...: Auto
x Trd2wr(Same/Diff Rank)..........8...: Auto
x DIMM1 Clock Skew Control (ps).......: Auto
x DIMM2 Clock Skew Control (ps).......: Auto
x DDR Write Training..................: Auto
>>>>> Channel A Driving Settings......: [Press Enter]
x Driving Strength Profile............: [1066MHz]
x Data Driving Pull-Up Level..........: Auto
x Cmd Driving Pull-Up level...........: Auto
x Ctrl Driving Pull-Up Level..........: Auto
x Clk Driving Pull-Up Level...........: Auto
x Data Driving Pull-Down Level........: Auto
x Cmd Driving Pull-Down level.........: Auto
x Ctrl Driving Pull-Down Level........: Auto
x Clk Driving Pull-Down Level.........: Auto
>>>>> Channel B Timing Settings.......: [Press Enter]
>>>>> Channel B Driving Settings......: [Press Enter]
****** Motherboard Voltage Control ******
Voltage Types..........Normal...........Current
>>> CPU
Load-Line Calibration.................: [Disabled]
CPU Vcore..............1.27500V.......: [1.30625V] (Five up from default)
CPU Termination........1.200V.........: [1.200V]
CPU PLL................1.500V.........: [1.570V] (One up from default)
CPU Reference..........0.760V.........: [Auto]
>>> MCH/ICH
MCH Core...............1.100V.........: [1.300V] (Eight up from default)
MCH Reference..........0.760V.........: [0.740V] (One down from default)
MCH/DRAM Reference.....0.900V.........: [Auto]
ICH I/O................1.500V.........: [1.500V]
ICH Core...............1.100V.........: [1.200V] (One up from default)
>>> DRAM
DRAM Voltage...........1.800V.........: [2.020V] (One up from default - DDR18V = 2.016V in PC Health Status)
DRAM Termination.......0.900V.........: [Auto]
Channel A Reference....0.900V.........: [Auto]
Channel B Reference....0.900V.........: [Auto]
******** Advanced BIOS Features ********
Hard Disk Boot Priority...............: [Press Enter]
First Boot Device.....................: [USB-HDD]
Second Boot Device....................: [Hard Disk]
Third Boot Device.....................: [CDROM]
Password Check........................: [Setup]
HDD S.M.A.R.T. Capability.............: [Enabled]
Limit CPUID Max. to 3.................: [Disabled]
No-Execute Memory Protect.............: [Enabled]
CPU Enhanced Halt (C1E)...............: [Disabled]
C2/C2E State Support..................: [Disabled]
x C4/C4E State Support................: Disabled
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.....................: [Disabled]
Virtualization Technology.............: [Disabled]
Delay For HDD (Secs)..................: [ 0]
Full Screen LOGO Show.................: [Disabled]
Init Display First....................: [PEG]
******** Integrated Peripherals ********
USB Keyboard Function.................: [Enabled]
USB Mouse Function....................: [Enabled]
USB Storage Function..................: [Disabled]
Thanks, I can get stable with 200d pl9, just got this ram and was trying for 1150 and up pl8. The ram is low voltage, pc2 9200 1.8v. http://www.newegg.com/Product/Produc...82E16820227457
