Case looks nice indeed:up:
But the tubing is soooo loooooong...:(
Yes, I'm a real low flow user, but the temperatures are still very good, because I only buy parts with a good performance AND a low flow resistance.
More than possible, I just confirmed my order with LeChuck today :D.
artic_storm, How low is the flow rate man.
Atleast save yourself a bit, and use shorter tubes where possible. Like from the Box to Case.
Try adding a 2nd pump too.
What are your CPU and GPU temps?
Now thats what I like to hear. Now I jusy need to figure out what I want & pm him:) I haven't done any real water cooling since my abit nf7-S 2.0. I still have the radiator, shroud, pump, critcool relay thingy and the maze blocks for cpu & chipset. I'm so out of date on custom cooling I'm mostly reading right now. I'm purchasing another members high end parts & I'm trying to determine what to keep & what to let go.
Swiftech Storm Rev2
swiftech Apogee GT
Swiftech MCW30
Swiftech MCW60 with MC14 Ramsinks
Thermochill Radiator PA120.2
Petra'sTech DDCT-01s Custom Delrin DDC Pump Top (w/Barbs)
Laing DDC-2 (18W)/Swiftech MCP355 Inline 12V DC Pump
AquaXtreme High-Flow Fitting (G 3/8" Thread, 1/2" OD) for Thermochill radiator
EK High-Flow Fitting (G 1/4" Thread, 1/2" OD)
I welcome any input.
looks pretty nice
Thanks, Its all going in the same case as Been's.
You have the black pearl? :eek:
omg that case looks amazing im confused is it custom made?
If you live here in the states the case is called Tagan Aplus Black Pearl & can be had @ newegg for $249 + shipping.
Nemesis, Start your own thread :). Itll get better exposure.
Plus, this thread is only to post completed WC'ing rigs.
PM him and ask him for English versions of his PDF files for the Cases. Then youll know what to PM him ;)
looks exactly like a lian-li v2000b
Yes Grinch the Black Pearl is exactly the same as the ll v200b but the front is not the same and it has a fan controller at the front :) And its not manufactured by Tagan its manufactured by APLUS (A+) as you can see on the blue glowing Logo on the front.
http://img111.imageshack.us/img111/8352/frontox1.jpg
http://img442.imageshack.us/img442/9518/imag0001xm4.jpg
http://img442.imageshack.us/img442/2695/imag0002yt8.jpg
Thermochill P120.3 inside :P Feel free to ask me :)
Case Open Pics??
Hows the Rad mounting in that Cabbie?
http://benstyle.de/projekt/tubed2.jpg
http://www.imagebanana.com/img/qawgndho/IMAG0002.JPG
But now the fans suck the cold air from the bottom :)
Nice!...
You still had to mod the case by the looks of it?
Was there already a place for the Triple Rad down there? Modding only for PA120.3?
What are your temps like? Also, What pump? And why CPU and GFX last in the loop? :O
But be sure, that the dust is harder there ;)
Hey Been, I have changed my way of tubing now.
So I can remove and plug in my soundcard again :D
Just a link, because the pic is just too big. *klickme*
This Pic is just a test-setup. I have to clean up everything now. Also the Laing-Reservoir is removed and replaced by my other one in the front again. (fass-o-matic)
http://i18.photobucket.com/albums/b1...on035Large.jpg
Didnt watercool the GPU as i didn't know how crappy a MCW50 was until i opened it up. :(
Looks good lowfat.
Very simple. And good work on the cable management :)
yes lowfat simple is good.
btw you should try elevating outlet of res so it is higher than inlet of pump...
its safer that way, prevents your pump from running dry, unless your pump can run dry and has some sort of high sucking power.
When the res is full, water flows right into the pump. It is only a few millimeters lower than the pump, it just looks lower in the pictures.
I also think it is more important that actually the water level in the reservoir is higher compared to the inlet of the pump. And that´s given here.
