2500 7-11-7 from the 2133 7-10-7 kit:
1.77v VDIMM
http://img97.imageshack.us/img97/2660/5224cineweb.png
1.77v VDIMM
Nice clocks BeepBeep2! :up:
I really wanted a kit of Flare with the tighter +2 TRCD for Phenom II but I'll take ram that does ~2400-2500 C7 @ +4 benchable any day :D ...Hypers cant match that at all, I'm lucky to hit 2350 8-8-8 benchable with those. (Which is possible.)
For 24/7 clocks its a toss up between Elpida Hyper and PSC for 4GB kits, Hyper doing 2100 CL7 comfortably and PSC doing 2200 at TRCD +3.
I'm pretty sure I could do 2700-2800 CL8 with CPU under LN2...unfortunately ~2550 is limit on anything but SS/DICE/LN2
3ghz in single channel is nothing to laugh at, very nice!
Prime run with two of these Kits on Sandy Bridge-E
2400 CL 10-11-10
http://www.abload.de/thumb/4700-1376...prime4mb3u.png
These kits need really low VCCSA and VTT.
had no luck for prime with CL 9-12-9 2400, any ideas?
Sound more like IMC issue...
I'm not familiar with adjustments you can make on SB-E to help, but the kits are easily capable of 2400 8-11-8
