Thanks - I will give that a go :)
Did you try running Memtest86+ overnight? It might be because of memory instability.
No I can run your test fine. I thought about it and this is just saying the program took awhile to open that's all it isn't actually talking about it starting with windows.. I just wasn't thinking before posting sorry bout that. I love your program it is awsome.
Lol, I used it on my Eee PC and it only got up to 66C. Not bad. :)
squito, have you tried hyper pi with the compatibiltity options checked? http://www.xtremesystems.org/Forums/...d.php?t=176904
vista's audio service and themes have been found to cause problems with super pi
Option 1: maximum memory, is obviously the best test for RAM, but how about when I want to test vcore, NB, VTT (GTL)?
And Is 10 passes good enough, for a indication for daily stability for gaming and some encoding? Or how many passes do u guys recommend?
Looking good overnite :up:
HyperPi actually when ran runs times slower then superPI .. now what youc an do is open HyperPi and check off the three items that Vista needs to be checked off for Super Pi to work and then leave it OPEN and then open Super PI and run it ... :)
Works every time.... and once done . uncheck those three things and close Hyper Pi and then do your screen shot of Super Pi ... :)
After playing some more, I found the following problem. IntelBurnTest will not run in maximum stress test with the page file disabled. So if you are getting this error, turn your page file back on for testing. It frees up more memory that is reserved by the OS. Turn it back off after testing.
IMO 50 passes is a good test, probably 40 is acceptable too, but I have failed between 20 and 30 tests before so I would recommend going over that to be perfectly stable. 10 is a good start when when messing with settings, but before you finalize 50 is a better test.
hmmm I passed 20 passes @ linpack but prime small failed within 2 min.... could it be because of XP32bits? I just got 2GB RAM tho....and it should utulize all RAM?
Updated to v1.6
- Added updated 32-bit and 64-bit Intel(R) Linpack binaries from Intel(R) [August, Official]
#EDIT:
Updated native 64-bit WinPE version as well.
I love this program, but is there a chance it pushes a CPU to an unrealistic point which is unlikely to ever be reached in regular use?
Just a thought. Don't bite me!
Silent data corruption is always a hazard... this is one step closer to error-freeness.
If the numbers in <norm> dont match, what does it mean? Unstable memory and CPU?
