New result screen (read file pi_rec.dat2):
Official site: http://www.virgilioborges.com.br/virgilioborges/hyperpi
Download version 0.99b here (~500KB)!
CPU Intel QX9650![]()
Thermalright Ultra-120 + 12cm Panaflo Medium Speed
Asus Maximus Formula (Rampage BIOS 0403)
2x 1GB Geil Ultra PC-6400 CL4-4-4-12 2.1v
XFX GF 8800GTS 320MB DDR3 Extreme Edition
RAID-0: 4x Seagate 250GB NCQ 16MB
SB Audigy 2 ZS
OCZ EvoStream 600w
CPU-Z Validation
Screenshot!
Been waiting for something like this
Heatware | Abit IP35 Pro | Intel E6750@3.8Ghz 1.56v | Storm R2 | Ballistix DDR2-8500 | Sapphire HD3870 512MB@TBA | MCW60 | WD Raptor 74GB | WD2500KS | OCZ GameXSteam 600w | SoundBlaster Audigy 2 ZS | DT770/80Pro | WinTV PVR-250 | Antec P180 | 7 Yate Loon D12SL-12 | AQ50Z | PA120.2 Custom Painted | BIP GTS 120mm | MasterKleer 7/16 Tubing | VX924 | G15 Keyboard/G5 Mouse/Steelpad QCK+
Everytime i ran it with Vista SP1 it failed...stopped working.
Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
CPU: i5 3570k @ 4.2 Ghz
Memory: 2x4gb Kingston HyperX @ 1600Mhz
Graphics: Sapphire 6950 Toxic on BenQ XL2420TE
Board: ASUS Sabertooth Z77
Power: Corsair AX850W (70A)
HEATware
Currently playing: Planetside 2, Dead Space 3, Call of Juarez: Gunslinger
Doesn't work on XP...on both machines i tried it on.
Computer:
Case: Corsair 750D Airflow Edition
Mobo: Gigabyte Aorus X570 Ultra
RAM: Team TForce Xtreem ARGB 3600C14 2x16gb XMP
CPU: AMD Ryzen 5900x
Graphics: EVGA (rip) RTX 3080 FTW3
PSU: Seasonic Focus GX 850w
Cooling: Arctic Liquid Freezer II 360mm
NVMe: SKHynix P41 Platinum, Samsung 980 Pro 2tb
SSD: Micron 1100 2TB, Samsung 860 Evo 1tb
HDD: WD SE 2TB, WD Black 1tb 3 platter with over 10 years of power-on time
Works for me on XP![]()
first, off, i am loving the Hyper Pi front end. after 98B it has been a treat to work with. the first version was a little sluggish but your first update has really made it an excellent multi-pi front end. haven't even touched 99B yet but will start using it now.
one small suggestion though, it would be less confusing if you kept all your updates to one thread. you have the thread in the Xtreme Benchmarks section and it would be really nice if you simply updated the first post in that thread with a build log and each new version you post. otherwise you have different versions floating around and no one knows which is the newest. the guys who did CoreTemp and Memset have done it like this and it worked out rather nicely having a single "home" thread...this one:
http://www.xtremesystems.org/forums/...d.php?t=172569
other than that, keep up the excellent work, Hyper Pi is now the only way i run Super Pi for stability testing. it is working fine on Vista Ultimate x64 and fresh installs of XP Pro on P35, X38, and 790FX chipsets for me![]()
with one thread it has all the cache to itself, with two threads it has to share the cache and this slows both threads down.
One Core Score is faster than Two Core Score. Why ?
Great. Will test it soon.![]()
F-Secure Client Security anti-virus thinks it's a trojan.
:P
You were not supposed to see this.
This is actually slightly quicker (0.1s) than Super Pi mod 1.5 XS on it's own even with a normal priority (IME). Tried them earlier today on both a Q6600 and a Phenom 9600BE.
You did not like, therefore you do not know the objective of the HyperPi, and at the very least you find that it is for substituting the SuperPi. But a simple way for you to understand, since failed to understand the objective, the HyperPi is only for being able to run the SuperPi in Two or More nuclei at the same time of beginning.
awesome!
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
is there going to be a linux version on source code?
ran once, and 2 seconds slower that super PI on q6600 (ok efficiency np) but running second time froze the comp, and its super stable, not even oced much just at 3200, oh running win2003 server
SuperPI in the Hyper pi doesn't show up even after 5 minutes. However amazingly this superpi from hyper pi folder is working :o any other downloaded version of super pi isn't working.. a ug mybe?
awesome! works fine on my winxp sp3 machine!![]()
1. Asus P5Q-E / Intel Core 2 Quad Q9550 @~3612 MHz (8,5x425) / 2x2GB OCZ Platinum XTC (PC2-8000U, CL5) / EVGA GeForce GTX 570 / Crucial M4 128GB, WD Caviar Blue 640GB, WD Caviar SE16 320GB, WD Caviar SE 160GB / be quiet! Dark Power Pro P7 550W / Thermaltake Tsunami VA3000BWA / LG L227WT / Teufel Concept E Magnum 5.1 // SysProfile
2. Asus A8N-SLI / AMD Athlon 64 4000+ @~2640 MHz (12x220) / 1024 MB Corsair CMX TwinX 3200C2, 2.5-3-3-6 1T / Club3D GeForce 7800GT @463/1120 MHz / Crucial M4 64GB, Hitachi Deskstar 40GB / be quiet! Blackline P5 470W
This works for me.. Vista x64 SP1. But all is not good. For the 1M, I get 18 seconds. Using just SuperPI alone (which also works fine), I get 11 seconds on the 1M.
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
—Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
Hyper Pi 1.0 will be released soon...
Thanks for support.
SB Audigy 2 ZS
OCZ EvoStream 600w
CPU-Z Validation
Screenshot!
