which BIOS solarfall? the 802?
guys, anyone know MAX dualchannel Fsb?
hmm sweet .. maybe there is hope ... i can only get my ram to 1069 stable ... and its rated at 1066 ... hopefully this bios will help me get to at least 1100 or something ...
solarfall, why does memset say you have ddr3? is his a bug in memset or the BIOS? or do you have a magical maximus II that uses ddr3?
hey guys... could somebody explain to me the gtl settings, please?
how should i calculate this with the fsb & vtt voltage for a 65nm cpu?
@Solarfall
May i beg you to post yoru settings for FSB600 ?
Like VTT VNB and GTLs & PLL etc
I am stuck at FSB 550 :shrug:
im using these ones http://www.ocztechnology.com/product...lexxlc_edition
@solarfall
Can you pls post your Bios settings ?
Especially VNB VTT PLL and GTLs would be nice. :up:
anyone know what water block will fit on the northbridge without taking out all of the heat pipes?
only one that i've seen tried on was an MCW30 with some slight mods to it
:D
http://www.xtremesystems.org/forums/...d.php?t=194858
:rolleyes:
ooooh sweet ... very nice rob :up:
mr-rob beat me to it
on another note, does anyone else have an issue with the memory showing up as ddr3 on cpuz?? not sure if it's my memory, the mobo, or cpuz. memory is OCZ gold ddr2 800 and it reads fine on other mobos and any version of cpuz, but on maximusII, it's reads ddr3 no matter which BIOS or cpuz version. relaxed the timings and still no difference
http://img.photobucket.com/albums/v2...gon/cpuz-2.gif
yep its a bug ... mine also says DDR3 ....
I tried crossfire today the result is not as good as I thought
pic 1 stock cpu single 4870
Pic 2 stock cpu 2x 4870
Pic 3 OC cpu single 4870
Pic 4 OC cpu 2x 4870
pretty CPU limited there, we benched the P5Q dlx with 2 4870's and got 23K fairly easy with a quad 4ghz... driver issue ?
I have my Maximus II Formula w/E8500 OCCT and everest stable but the machine reboots with some frequency even at idle.
Am I having a hardware problem or is there something else that I am missing.:(
If it's at idle and never under load it could be loadline calibration that plays parts... try a bit more Vcore...
Maximus 2 under Dry ICE :cool:
E8500 + 2x 3870 X2 CF + Maximus 2
3D Mark 03:
http://www.abload.de/thumb/11534303f7l.jpg
But the VCore was only 1,8V, not 1,92V :ROTF:
http://www.abload.de/thumb/bilder025hgw.jpg
http://www.abload.de/thumb/bilder02602q.jpg
We had a problem, our power supöy was to weak, so we can not go over 5,15 Ghz, yesterday we try it with a P5E Deluxe Board and one 3870X2, we can run 5,25 Ghz with only 1,7V.
The next session will come, then we take a stronger power suply :D
Here more Pics:
http://freeocen.de/wbb2/thread.php?t...tuser=0&page=1
