AMD's problem wasn't the 512bit bus.
Regardless whether it's expensive or not, it's the way forward, we had 256bit bus since forever.
And I'm sure that the 512mbit bus on the R600 wasn't what made it so expensive, rather poor yields had more to do with it I reckon.
What does that have to do with anything? Both companies taped out chips for this gen obviously.. whether it's DDR3 or DDR5 just becomes a matter of cost then.
By the way, changing memory as a method of avoiding taping out an extra chip makes no sense at all.
You really think the chip is going to be the identical chip that ends up in a laptop?
Neckbreaker and AMD is usually refered to as economics. And since RV670 is basicly a R600 with half the bus you should eb able to put 2 and 2 together.
GDDR5 will be cheap enough for the cards needing it. And its cheaper than going 512bit. AMD went 512->256bit. nVidia went 384->256bit. Notice the trend?
That doesn't mean its not necessary... we've seen cases where 256-bit hurts performance vs. 384-bit and 512-bit. It's not much of an obvious need-based trend when you're talking about each company needing to keep up with their competition in terms of costs for their products. If they choose to go the costlier route, they automatically lose out in a price cut war. No one wants that disadvantage, so they happened to match each others 256-bit specs last round because it was the logical thing to do (offer a value card).
This time it's two different costly approaches to increase back to 512-bit bandwidth levels. So much for any trend..
http://www.pczilla.net/en/post/11.htmlQuote:
GeForce GTX 280 got 7k+ in 3DMark Vantage Extreme Test
We learn from pcinlife forum that GeForce GTX 280 graphics card can get 7k+ scores in 3DMark Vantage Extreme test, double the score of 9800GX2 in 3DMark Vantage Extreme test. But now we still don’t know the specification of the test hardware and software configurations.
We learn that GeForce GTX 280 graphics card is equipped with 512-bit 1GB DDR3 video memory; it has 240 stream processors with 250W power consumption. GeForce GTX 280 graphics card uses dual slot cooling fan,
We also heard there’s no problem for GeForce GTX 280 graphics card to run 1920x1200 with AA and AF in Crysis.
Nice if it would be true. xD
That would be a huge performance boost jump to today's gpu market. Well if these rumored specs really are true then I don't see why it couldn't. Now this wouldn't necessary mean 2x performance in PC games but it's sure speaks for some nice performance boost in any case.
But that last sentence is a bit fishy to me. If Crysis runs fine at 1920x1200 with AA and AF, either AA & AF is handled severly more effective now (yea SPs numbers have increased a lot) but it would have to increase more than 2x the performance currently to run Crysis 1920 x 1200 fine with AA and AF. 1GB vidmem could help a lot I know here and the high bandwidth, I dunno, I'll just believe it when I see it.
ehh, that sounds like they are just posting what people want to hear to get hits, double the 9800gx2? That's at least 3 times the performance of g80, not going to happen unless if that setup was oc'd to the extreme or was a dual gpu setup
Well I don't think 3DMark Vantage for starters will be a good indicator how PC games will run like which will probably see a less benefit (when I hear 2x higher 3DMark Vantage score my mind goes automaticly like, ok prolly 50 ~ 60% pc game performance advantage) at least today's popular ones but upcoming PC titles might see a little bigger improvement.
I'd love to see some leaked PC game performance tests. :p:
hmm 250W... includes H20 cooling. :D
250W against 159W from RV770? That is kind of a big difference there, dont think it will be 250W unless it turns out to be a dual gpu card, which is ofcourse useless (unless u wanna brag about having the fastest card on the market) and a waste of electricity.
Bus size doesn't mean that much at all. My old G80 GTS has 320 bits bus, more than the current GTS with their 256 bits but its a slower card. They need to make the card powerful enough to actually use all the bandwidth in order for the size to matter.
512bit MC
1GB DDR3
240 Core
250W
2X performance of 9800GX2 : 7K+ Vantage Extreme preset
Crysis at 1920x1200 with AA/AF no problem
source:
http://forums.vr-zone.com/showthread.php?t=277971
More than 7000 points in Vantage Extreme?!! :shocked:
If its true than RV770 and R700 is history.
not really. if the price of the RV770 is lower, then its really a "you get what you pay for" situation.
(very) small pix of gt200 pcb
http://www.itocp.com/thread-8904-1-1.html
