Settings for the above overclock. It was still Priming, but I'm about to go to bed so I checked out the BIOS settings before I turn it all off (I don't want anything exploding while I go to bed... I had a bad experience with a P5K-VM :))
X3350
L803A756
SLAX2
03/06/08
Mutiplier 8
FSB Strap 266
FSB 475
PCIE 100
DRAM 949
DRAM Timing Control 5-5-5-15-15-42-15-15-15 (super loose to make sure RAM isn't holding me back)
Clock Over-Charging Mode 0.90V
Spread spectrums Disabled
CPU Voltage 1.5250 (hardware monitor shows jumpy voltages between 1.464 - 1.440 at this setting)
CPU Voltage Reference 0.61x
CPU Voltage Damper Enabled
PLL Voltage 1.50
DRAM 2.10
FSB Termination Voltage 1.36
North Bridge Voltage 1.55
North Bridge Voltage Reference 0.61x
South Bridge Voltage 1.05
