same here George
it just doesn't work :shrug:
same here George
I have a few ideas (not CDT related though) to tweak spi a bit. I havent seen them anywhere else either so they maybe originals :) If they work I will create a thread to share. Since I believe thats what the spirit of all of this is about. Learn from others, share what you find back to them. Secrecy serves noone, except people's egos.
http://www.abload.de/img/spitweakeryqh.png
This is a one click waza :)
please test it ! and report
The Tool make a "Waza" Directory on the Second Partition (A) including some single waza files and copy this to the SPI Partition (B).
The "Clean Button" clean the system (remove .tmp , bak and other files ) like OPB's cleaner
The "Burn Button" should help under LN2 (make simple FPU division) , because some CPU's like cold temps only under load when the Idle Cold-Bug is much higher.
Playing with WAZA Size and single file size! could optimize your Spi32m time.
The CDT Checkbox activate CDT Copy Waza ( Partition A -> B -> A -> B)
Good job monteboy :)
Nicely done, ill test it when i have time ;)
new Version 0.9b
good work monteboy and the people involved in it...
This app should rocks, considering the people behind it...
Keep coding it...
Monteboy, Can I host your tweaker off the pi page?
I will give full credit to the author for creation.
Nice tool monte!
And now on teh official pi page! :up:
Oh that is a very handy tool! Tx for doing that.
Works great for me;)
ooh must try. thanks Monteboy
GREAT WORK monteboy.
More programmers like you would make benching ALOT more fun :D
Thx for your hard work :D
monteboy you the man! im getting 35lbs of dry ice tomorrow and will be punishing my 8500 ES (on a P5B Dlx) so now I will be using 2 of your proggies, Strap tweaker and copy wazaa! thanks a bunch!!
monte for president :rofl::D:up:
Awesome, where can i find the strap tweaker btw?
thanks monteboy!
Quick loose timing run with monteboy's SPI Tweaker with my new E8500 Q740A479T - didn't do anything other than set the pi directory to my setup's config and left 384MB waza file and still shaved off 1.703 seconds off my standard times :)
http://valid.x86-secret.com/cache/banner/381265.png
Before SPI Tweaker
http://fileshosts.com/intel/Asus/Bli...9s031ms_tn.png
After SPI Tweaker
http://fileshosts.com/intel/Asus/Bli...r_settings.png
http://fileshosts.com/intel/Asus/Bli...tweaker_tn.png
Now to play with waza file sizes :D
EVA try using a file 1/2 the size of your installed memory and see what happens.
THX Eva2000 for the quick test !
New Version 1.0 beta
Changes :
- Add a new checkbox to control the application exit after execution of copy-waza.
- Show current CPU Speed
i'll try it today, back to lowclock challenge game :].
Great tool, monteboy for president +1 :).
looking good shaved 5 secs at 8x500FSB 1:1
http://fileshosts.com/intel/Asus/Bli...1m24s687ms.png
would be nice to have a leaner/smaller GUI windows size :)
oh the lower divider reports cpu speed ast 9.5x500FSB not 8x500FSB heh
