These screenshots are real. Tamas told me that Everest can read L3 on AMD, and the cpuid is correct.
Well done Fuad :up:
Does that mean that L3 is activate?
Do you know why Everest is saying that 512KB Cache L2 i asynchronous??
http://www.fudzilla.com/images/stori...celonak10a.jpg
I found the machine above as well, it had a stress test running on all four cores but the way they set it up you couldnt tell what was going on, the screens would flash too fast to make anything of what was going on.
I plugged in a mouse and stopped the stress test, I went into everest for screens.
The plaque on the side said it was an Opteron 2200
nemrod> remember previous screenshots of cpuz showing a L3. As I mentionned, cpuz does not look for L3 on AMD, so this information was wrong. Everest does look for L3, and therefore there is nothing irrelevant in displaying one. A latency test would tell if L3 is really activated (and what its latency is).
Lightman> Asynchronous refers to a cache design. AFAIK, K8 also uses an asynch L2.
I'm confused...
Asynchronous for me means clocked differently than core, but in K8 L2 cache is clocked @ core speeds.
Maybe it might be clocked with different speeds like caches from first K7 Slot CPUs??
Anyone to enlighten me...
EDIT:
After 20 minutes of thinking and digging....
Look at this and compare to QC screen:
Attachment 60327
On my machine Everest 4.xxx.xxx is showing L2 cahce as 'Full speed'.
This lead me to theory that L2 cache in K8 really is asynchronous and AMD can change it's multiplier. This also can answer why Everest picture of QC part is showing L2 cache as Asynchronous... simply it's not Full speed, it's clocked at different than 1.6GHz clock (probably 1/2 or 2/3 of core speed).
This theory is in conjunction with what Groo and some other people was saying... Demoed K10 is cripped... It's not fully working part!
AMD noted that the memory controler will be clocked a lil' higher than the core it self. That may have something to do with it.
Wierd, cause exactly one month ago Groo was reporting that the B0 stepping had come back and resulted in a "massive gain in frequency", that as a result we could expect 2.9 GHz quads at launch, and that they were 'dancing in the aisles' over at AMD.
Now Groo says that same B0 is "so broken" and so full of "bugs and more bugs" that any benchies taken of it should be disregarded as worthless. Methinks he needs to go back to AMD marketing and tell them to straighten out what story he's going to be peddling next week.
No need in any theory - it is known that those were engineering parts.
It even could not be other way.
The Barcelona servers at Computex are all running engineering samples of the chip that were provided to help server makers build their systems.
http://www.theinquirer.net/default.aspx?article=40181
AMD puts out Phenom teaser
Anyone know anything that is happening on June 10th in Montreal?
I didn't get the hint from the INQ the first time, apparently Formula 1 racing. Why not May 13th in Barcelona though :D
sounds like the quad phenoms are going to be very pricey.... right around when intel drops prices on their quads... i do hope amd builds a reasonably and competitively priced quad chip.
Yepp.... :yepp:
Check this out: :up:
http://xtremesystems.org/forums/show...6&postcount=36
AMD want make big shows, they want to be the only one on the spot ligts, in the computex show evrey body is under spot lights.
maybe a idf like at montreal sunday with Barcelona. I'm asking myself why AMD cut the opteron prices if K10 is not on time ? :confused:
maybe it's a soft lunch and the cpu will be available on jully :shrug:
Has AMD ever sandbagged before (like at K8 launch)?
It's just wishful thinking (even on my part :() to expect K10 desktop to make an appearance before Christmas...
Suman
Just wondered, if 1.6gz is doing the rounds. How would that translate to the POV results?
Wouldn't that translate quite well?
All speculation ofc.
The POV results were ran at the same current vs Barcelona generation Opterons speed (i.e. Opty @ 1.6 and barcelona @ 1.6 or both @ 2.0 - doesn't matter which one, it still puts the barcelona in the slower-than-K8 ranks).
Barcelona is not delayed, AMD lunatic information formally, Barcelona is for this summer.
source ( french )
