Mike89, did you try 402 MHz FSB?
No, I tried 401.
I've seen mention here about a 903 BIOS? The Asus website lists only one, the 804.
mike did you lock pci @33 it sounds like pci is ocing with fsb
Yes, PCI locked at 33.33 and the other at 101.
Ther is a 903, 908 and 910 beta floating around.Quote:
Originally Posted by Mike89
910 is not beta, today I flash my board with it. In bios adds some USB new setting. OC ~15FSB better than 804.
BTW what was the problematic divider?
Really ? What's the change log ?Quote:
Originally Posted by Gam3Ra
If the 903 BIOS is not Beta, why does Asus not list it?
I flashed 908. could post in 530 on fsb.. for the fun of it I tried 540, sam v settings.. and haven't been able to start it since
Tried cmos clear?
About to fire mine up for the first time. WEEEE here goes guys.
Any idea where I can get those 910 bios? All I see on the website is 804.
Here are my system specs...what do you guys think I should be able to go for as far as FSB, core, voltage, and memory timings etc.... Let me know what you guys think I should be aiming for.
System:
e6600 Conroe
Lian-Li v2100plus II Case
OCZ Platinum pc8000 Ram (2gigs)
Tuniq Tower 120 cpu cooling
Default Nbridge cooling (I have thermalright HR-05 but not installed right now..too tired to install it lol).
EVGA 8800gtx vid card.
So what do you guys think I should start with the settings?
Go http://www.xtremesystems.org/forums/...d.php?t=127995Quote:
Originally Posted by mrt2
For link to 910 bios. I just flashed from 0908 to 10 and so far no problems.
hey all ive got a Xeon 3040 running @ 3.0 1.5350v and my bios config is the same as the 1st post in this thread.
my bios is 804
My problem is everytime i run orthos i can run a Large FFT test for hours and the same with Small FFT tests for around the same amount of time... But when i run a blended test it fails in minutes..... I have tried playing with the voltages and everything and no go.... any one have any ideas?
Blend is usually a memory problem. First try this on blend..... from the dropdown menu select "Custom"..... change the "memory to use" box to roughly 1/2 of your system memory. If that does not help things I'd suggest Memtest-ing you memory to it's max, then dropping down 2-3 mhz for a saftey margin in Windows. I've always found my memory is not quite as stable in Windows as my max in Memtest.Quote:
Originally Posted by (clanger)(doa)
maybe just hit the memory with a tad more voltage or loosen the timings some??
they are d9's at 2.4 vdimm and timings of 5-5-5-5-15Quote:
Originally Posted by cdelong
ya think they can take more vdimm?
I'm not sure you even need 2.4v? I've run my Ballistix DDR1000 @ 2.15v up to 475fsb w/ a E6400 and 7x multiplier. You need to run memtest.... test #5. Let it run for 30 minutes. If you don't get any errors, startup normally with the same settings. Like I said, sometimes in Windows you will have to back down a few mhz to keep from borking your OS.
Well just out of curiosity I tried the voltage settings in the screen shots at the beginning of this guide and now my pc won't post....what should I do? Is there a cmos clear jumper?:(
turn off the PSU and unpluged it for a minute. Now plug it back in and turn the PSU switch back on. before booting your computer press the Insert key and hold it down. Keep holding the insert key down while you press the power button to start your PC. It should start right up.
On occasion I have had to do it twice in a row for it to post.
My cpu is running at 60C isn't this mega high? My multiplier is 7 and FSB is at 450. I tried to run my fsb at 500x6 and it boots but freezes....
Any suggestions on how I can get my FSB higher and also why my load tem is so freaking high?
PBDelux Wife/AP
Tuniq Tower 120
Lian-Li V2000 Case
high voltage = high heat. try dropping the vcore, i assume since you said you set them to fcg's settings you are @1.5 vcore which is alot.
you guys are awsome.... THANKS
CHECK IT OUt 3000mhz and stable.... changed the ram timeings and backed down the vdimm to 2.25v presto stable and this chips got more megahurtz in it i hope to hit 3.4 you guys rock.
I even think i can back the vcore down too...
http://i53.photobucket.com/albums/g6...us/3stable.jpg
Any suggestions for getting my FSB at 500+? Also I have OCZ Platinum pc8000 RAM, do you guys think I could set my ddr2 to 1200(the next step up from the current) instead of 960? Would the performance gain even be worth it? And one last question, I'm currently running the 0804 bios... Are the 0908 bios for the p5bdeluxe interchangable with the wifi version? Are all the p5b deluxe bios usable for al lthe deluxe version boardS? If so, where would I get the 0908 bios from? =)
I know it's a lot of questions but I really appreciate all the help you guys are providing, it's really helping me tweak my board. :toast: :woot:
ok currently I'm at:
FSB= 480
Multiplier= 7
DDr2-960
PCI-E Frequency- 110
Memory Voltage- 2.25
Cpu Vcore- 1.425
FSB Term Voltage- 1.45
NB vCore- 1.45
SB- 1.6
ICH Voltage- 1.215
Oh yeah and my current cpu temp is 56C is that decent or should I try to lower my cpu vcore more?
To get over 500 stable raise your NB and SB voltages.Quote:
What is your memory timings at 960? Try loosening timings/raise memory voltage and test using memtest to see if your memory is stable at 1200. There is a bandwith improvement even with looser timings. My Pcmark, 3DMark and Pi scores improved for me.
The 0908 or 910 Bios also works for the Wifi. I am running 910 with no problems. The only improvement I have seen is the ability to run the same OC with a little less vcore.
You can get the bios from this thread:http://www.xtremesystems.org/forums/...d.php?t=127995
Is 56c your load temp? If so your fine. If it is Idle you need to improve your cooling or lower your vcore which will reduce your OC.
I have a voltage issue. Here is my system specs.
P5B Deluxe
E6600 L629B361
Scythe SCNJ-1100P CPU Cooling
Arctic Silver 5
G.SKILL 2GB (2 x 1GB) Model F2-6400CL4D-2GBPK
CORSAIR 520 watt PW
XFX GeForce 7900GS 256MB
Seagate Barracuda 7200.10 320 gig sata
LITE-ON 16X DVD±R DVD Burner sata
COOLER MASTER Centurion 5 CAC-T05-UB case
Bios settings
Bios 804
CPU 401x8
DDR 802
PCI F 100
PCI Clock 33.3
Spread Spectrum Disabled
Memory Volts 1.9
CPU V Core 1.225
FSB 1.3
NB 1.25
SB 1.5
ICH Auto
C1E Disabled
Max CPUID Disabled
Vanderpool Enalbled
CPU TM Enabled
Execute Disable Enabled
Memory 4,4,4,12,4,42,3,10,5,13
It runs fine. I have run Orthos for 6 hours on Blend. I have looped 3DMark 03 and 05 for 2 hours. With the volts on 1.225 it says it has 1.18 at idle and 1.16 under load. My temp is 43c at idle and 60c load on pc probe, 41c idle 56c on Intel Thermal. If I set the V Core to Auto it chks. 1.12 in pc probe. If I turn the V Core to say 1.3 the temp goes up. I'm wondering if I am not getting a true reading.
Here is CPU Z and asus probe
