Yes, and thanks! We are currently looking for more Q6600 temps in the Water Cooled section of the board. :)
The Un-Official Q6600 Chest Pounding Proves Nothing Water Cooled Temp Thread!
http://www.xtremesystems.org/forums/...d.php?t=176531
I should tell you though that more fine tuning was done on my every day 3.8GHz Bios settings.
I primed for 2 hours using my above 3.8GHz settings, and encountered an error on 1 core. My guess was it probably was just Core voltage issue, but remember when Priming 3.9GHz I needed a wee bit more CPU PLL voltage too.
Allot of the boy's are running more NB voltage than me and my 1.51v's, so I took that up a notch too to 1.55V's.
I also moved my South bridge voltage from 1.05v's to 1.075v's for no good reason. :)
I cutt Prime95 loose again to see if my 3.8GHz would still have an error in 2 hours. My result was an error free 4 hour run, and me adopting these new settings.
My 4hour error free run using my 3.8GHz settings. Room temp was a brisk 55°F in my cold Ohio basement: :p:
http://img216.imageshack.us/img216/8839/run10yv4.jpg
These are my current best BIOS 907 settings for 3.81GHz:
Under Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : Auto
CPU Ratio Setting : 9
FSB Frequency : 424
FSB Strap to North Bridge : 400
PCI-E Frequency: 110
DRAM Frequency: DDR2-848MHz
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 18
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
DRAM Static Read Control: Enabled
Ai Clock Twister : Strong
Transaction Booster : Auto
CPU Voltage : 1.5120v (BIOS)
CPU PLL Voltage : 1.58v (BIOS)
North Bridge Voltage : 1.55v (BIOS)
DRAM Voltage : 1.80v (BIOS)
FSB Termination Voltage : 1.44v (BIOS)
South Bridge Voltage : 1.075v (BIOS)
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : DDR2_REF
SB 1.5V Voltage : 1.50v (BIOS)
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED : Enabled
Under Advanced
And CPU Configuration:
C1E Suppport : Disabled
CPU TM Function : Enabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
Under Advanced
And USB Configuration :
USB Functions: Enabled
USB 2.0 Controller : Enabled
BIOS EHCI Hand-off : Enabled
Port 64/60 Emulation : Disabled
Legacy USB Support : Enabled
