For the 965P-S3 and F7 users
I have a good feeling about F7. At 480x7 using F6, I could run Orthos blend for 19+ hours no problem.
The issue, I was having was failing dual super Pi 32M, could not do it.
Today flashed with F7 (went back to defaults before flash). Booted checked things out. Reboot back to bios and reset to my 450x7 numbers. After saving settings had the shutdown, restart, shutdown, restart...beep,beep...deal. Shut it down. Startup back to bios. Changed vcore up notch from 1.325v and went up to 2.2v on mem, added +.1 to mch and fsb. A couple of more shutdown restart shutdowns and finally booted to xp. Ran dual Pi 32M passed. Once you get past that, things will start to look good.:D
Restarted and change bios back to my F6 numbers.
450x7 ~3150
1.325v bios
FSB v: normal
(G)MCH v: normal
Firestix FSX800D2C-K2G 2 4 4 4 12 2.2v
Booted to xp, completed dual Pi 32M
Moved on to
480x7 ~3360
vcore 1.425v bios
FSB v: +.1
(G)MCH v: +2
memory Firestix FSX800D2C-K2G 2.3v 5 5 5 18 (Elpida E5108AG-6E-E)
44c-45c idle
58c-65c load (I really need to slap my maze I on this. This should be my 24/7 set-up)
19.5c-21.8c ambient
As I said, I ran Orthos blend for 19+ hours no problem with these numbers but, it would fail running dual 32M.
Today with F7 completed dual super Pi 32M. Currently doing an overnight Orthos blend. I about a hour in to it.
http://valid.x86-secret.com/show_oc?id=150891
AC Freezer 7 Pro
ZALMAN ZM-NB47J with fan on the NB.
CPU name E6300 OEM - lapped (paid $130 for it)
Stepping: 6 B2
Week: L624
Code: A954
will try 500x7 with F7 and water, been there on air with F6. But, it was not stable for me.
http://valid.x86-secret.com/show_oc?id=150635
