Originally Posted by
Ace-a-Rue
hey guys...testing a new beta bios and so far, i like it...Bingo13 (AKA, Gary Key with Anandtech) forwarded it to me for testing...he will post a link here in this thread very soon.
initial results:
1) i increased my overclock to 3915 mhz (435 X 9), so far, with successful benching of 3D2001, 3D2005, 3D2006, PCMark2005 and wPrime bench.
2.) could successfully run 4:5 memory ratio, which is the 1066 memory strap, at a slightly lower overclock of 430 FSB X 9 = 3870 Mhz....previously, could not set 4:5 memory ratio using my Dominators DDR1142 or TeamGroup DDR1000.
3.) the only annoyance is when i cold post/boot (could be caused by my high overclock)...i get a siren like sound coming from the mobo/case speaker when it starts from a power off...it is giving you the impression that the memory is out of limits...BUT...in about 2 seconds, the siren sound stops and it post normally....on a warm reboot, it works just fine.
i am still reducing my ICHIO (1.8) and MCH (1.64) to find my bottom point to support 3915 Mhz...i have 1.550 for vcore set in the bios and i am getting about 1.52 actual vcore...once all the low end voltages are found, i will start increasing the FSB to see if i can hold 4Ghz for benching other than Prime 95 type.
