For 12GB you may need to set Dram voltage to 1.68-1.7 and IOH to 1.20-1.28
Would there be any limitations with the RAM controller on the CPU itself?
Also I read that going over 1.65v could damage the CPU???
http://www.tomshardware.com/news/int...tage,6464.html
“According to Intel CPU spec, DIMMs with voltage setting over 1.65V may damage the CPU permanently. We recommend you install the DIMMs with the voltage settings below 1.65V.” According to Iain Bristow, spokesman for Asus, “the sticker had been placed on the motherboard after Intel’s recommendation.”
I currently have..
4.2 OC
Ratio: 20
BLCK: 200
SPD: 8
And Intel Turbo tech boost on to give me the 21 for added stability that seems to work well.
Any help really appreciated.
You only need to be sure you keep the dram voltage within .5V of the QPI/Vtt is all. It is not a 1.65V limit
Set command rate to 2T for 12GB.
Also increase IOH to 1,2-1,25V and VTT to ~1,4 that should do it.
1.4 :|
I'm getting a little concerned about the dram been within .5v of vtt... not something i've known about. (ops scotty)
What should I be setting that to?
you will hear both sides to the argument, my 1866 dominator gt's require 1.65v and VTT of 1.6v according to Corsair to run at their rated speeds...
More than 1,45V VTT on air WILL kill your IMC sooner or later. I killed the 3rd ram channel on a 940 after 2 weeks at 1,52V - on phase change (cold is supposed to help).
At the moment on 6gb @4.2ghz...
I have vcore 1.3 and I did have vtt as 1.355 (?) but I've been lowering it and then Linx testing etc
it's been stable.
Can you go as low on vtt as you need to as long as you maintaint the .5 between vdim and vtt??
I was wondering if anyone here knows what is happening with these EX58A series boards?
As someone posted on OcUK forum that they contacted Gigabyte via e-mail and another guy actually called them up to see when we were likely to be releasing these boards, and they were told that they wouldn't be hitting the shelves anytime soon, if at all.
Here is the post I am referring to:
http://forums.overclockers.co.uk/sho...6&postcount=34
I remember one of you guys on this thread saying they should be here by next month, but if what these people were told is true then we probably wont be seeing them for a good while yet, or maybe never.
I was actually looking forward to these mobos becoming available, but I guess that isn't going to happen now. :(
You dont need 1.4V VTT for 12gb to run, but it all depends on the CPU, the speed at which your rams opperate and on the bios version you are.
Im on 12gb with 1200mhz @ cl7 T2 running with VDIMM 1.65, VTT 1.355, Vcore 1.28x (Drops to 1,245) and works without problems so far.
Though im still on F4j cause all the other versions need either more VTT or more Vcore to be stable.
I do believe over 1.35-1.4 is fine, some XMP actually have programmed settings of 1.6 or more.
I made a post at TT about this, which links to OCZ's qualification and testing of some of their modules at 1.6V QPI/Vtt at stock speeds.
http://forums.tweaktown.com/f69/post...97/#post312297
As long as you keep QPI/Vtt within the .5 range you will be fine. Alot of the 1.65V ram discussions were made before anybody knew anything. I think if 1.6V was a dangerous QPI/Vtt voltage OCZ would not test, validate, and program their modules at this setting, nor would the publish it in public as they do.
Of course voltages are always up to the end user to decide what to use, but just keep in mind certain things (High Speed/Tight Timings) will not be possible without stepping outside of the ranges that have installed fear into everyone. Please do go have a look at the bove link, then follow the link in that thread to OCZ's page and have a look at some of their modules XMP Programmed settings.
bugger it.....
I'll stick with 6gb :|
Which ever way I do this it looks like speed some how is sacrificed.
So until there is someone who can confirm that I can go 12gb somehow without needing to loose much speed.
I will keep things as they are... luckily I can sell on the ram to someone who wants it.
OK...
Before I decided to try out 12gb i'd been working on stability on 6gb and I've been using the following.
Can anyone please highlight any problem areas for me?
6gb set up...
Clock 20x (with intel boost 21x)
BLCK: 200
Uncore: x 16 (3200Mhz)
QPI: x36
CPU Clock drive: 900mV (is this the best setting?)
PCI Expess Clock Dive 900mV (is this the best setting?)
Performance: Turbo
SPD: 8
Timings.
8
8
8
24
1
LLC: Enabled
Vcore: 1.356 (working on a 3.5v)
QPI: 1.175v
IOH: 1.160v
Dram: 1.660
CPU PLL: 1.8v
PCIE: 1.5
QPI PLL: 1.2
ICH i/o: 1.5
ICH Core: 1.1
Dram Term: 0.750v
Is there anything other than vcore I should be looking at lowering or highering?
well i can tell you now i can get my dominators to throw memtest errors when i back off the VTT at 1900mhz. Linx is great but it wont show errors all the time, memtest finds errors before i see any sign of instability, it likes to burst my bubble aswell :shakes:
ive just left it on 1.65ddr and 1.6vtt for now...its also a pain getting 1T stable at 2000mhz :(
I just OCed my i7 920 D0.
On the motherboard what are the 5 blue light, next to the CPU temp LEDs, for?
The DRAM and QPT/VTT voltages should not exceed 0.5v, right?
Also, what is your 920 D0 vcore @ 4.0Ghz? (turbo disabled)
QPT/VTT Voltage @ x36?
I know we don't have same vcore and QPT/VTT, but I just want to get an idea how high the voltages for i7 920 D0 stepping.
Since I am off of work today, I OC just the CPU, and downclock the RAM and Uncore.
CPU Blck Freq is the 5 Blue LED's
Keep your QPI/Vtt within a .5 range of Vdimm
The 5 blue LEDs are all lit up, is that good or bad?
The temperature LED's are not on, I guess because I disabled the thermal monitor.
Right now, I left the DRAM on auto since I downclocked my RAM & uncore.
What about the Voltages of 920 D0?
EDIT:
Can someone please post your 920 D0's BIOS 4.0Ghz template?
Sounds like a plan! Good luck with the tweaking!
Ya, B2B is supposed to help at high ram clocks, here is a review on the setting if you have not seen this already
http://www.madshrimps.be/?action=getarticle&articID=940
